Before posting
ESP32
V9.1
#include <Arduino.h>
#include <DHT.h>
#include <lvgl.h>
#include <HX711.h>
#define TFT_HOR_RES 240
#define TFT_VER_RES 240
#define DRAW_BUF_SIZE (TFT_HOR_RES * TFT_VER_RES / 10 * (LV_COLOR_DEPTH / 8))
uint32_t draw_buf[DRAW_BUF_SIZE / 4];
DHT dht(5, DHT21);
HX711 scale;
void Core0(void *pvParameters){
while(1){
vTaskDelay(10);
void setup(){
Serial.begin(115200);
dht.begin();
scale.begin(19, 18, 128);
pinMode(33,OUTPUT);
digitalWrite(33,HIGH);
lv_display_t * disp;
disp = lv_tft_espi_create(TFT_HOR_RES, TFT_VER_RES, draw_buf, sizeof(draw_buf));
xTaskCreatePinnedToCore( /* If core0 is not accessed, the error will not occur. */
Core0,
“Core0”,
8192,
NULL,
1,
NULL,
PRO_CPU_NUM
void loop(){
lv_task_handler();
delay(5);
Error Contents:
c:/users/.platformio/packages/toolchain-xtensa-esp32/bin/…/lib/gcc/xtensa-esp32-elf/8.4.0/…/…/…/…/xtensa-esp32-elf/bin/ld.exe: .pio\build\esp-wrover-kit\firmware.elf section .dram0.bss' will not fit in region dram0_0_seg’
c:/users/.platformio/packages/toolchain-xtensa-esp32/bin/…/lib/gcc/xtensa-esp32-elf/8.4.0/…/…/…/…/xtensa-esp32-elf/bin/ld.exe: DRAM segment data does not fit.
c:/users/.platformio/packages/toolchain-xtensa-esp32/bin/…/lib/gcc/xtensa-esp32-elf/8.4.0/…/…/…/…/xtensa-esp32-elf/bin/ld.exe: region `dram0_0_seg’ overflowed by 2080 bytes
collect2.exe: error: ld returned 1 exit status
*** [.pio\build\esp-wrover-kit\firmware.elf] Error 1
