Before posting
ESP32S3 (Waveshare 7" touch screen monitor)
v8.4
How can I update meter indicator position in main.ino code with signal from ADS?
Any online help and LVGL widgets meter documentation.
How can I update indicator position in main.ino code?
I’m following this ( lv_meter_set_indicator_value(meter, indic, value) sets the value of the indicator.) in lvgl documentation, in my code eez created like ( lv_meter_set_indicator_value(obj, indicator, 0)![]()
/*Code generated by EEZ v 0.22.0*/
#include <string.h>
#include "screens.h"
#include "images.h"
#include "fonts.h"
#include "actions.h"
#include "vars.h"
#include "styles.h"
#include "ui.h"
#include <string.h>
objects_t objects;
lv_obj_t *tick_value_change_obj;
static lv_meter_scale_t * scale0;
static lv_meter_indicator_t * indicator1;
static lv_meter_indicator_t * indicator2;
static lv_meter_scale_t * scale3;
static lv_meter_indicator_t * indicator4;
static lv_meter_indicator_t * indicator5;
static lv_meter_indicator_t * indicator6;
static lv_meter_indicator_t * indicator7;
void create_screen_main() {
lv_obj_t *obj = lv_obj_create(0);
objects.main = obj;
lv_obj_set_pos(obj, 0, 0);
lv_obj_set_size(obj, 800, 480);
lv_obj_set_style_bg_color(obj, lv_color_hex(0xff2e2929), LV_PART_MAIN | LV_STATE_DEFAULT);
lv_obj_set_style_bg_opa(obj, 255, LV_PART_MAIN | LV_STATE_DEFAULT);
lv_obj_t *parent_obj = obj;
// amp_rotator
lv_obj_t *obj = lv_meter_create(parent_obj);
objects.amp_rotator = obj;
lv_obj_set_pos(obj, 230, 80);
lv_obj_set_size(obj, 340, 340);
lv_meter_scale_t *scale = lv_meter_add_scale(obj);
scale0 = scale;
lv_meter_set_scale_ticks(obj, scale, 61, 2, 4, lv_color_hex(0xffffffff));
lv_meter_set_scale_major_ticks(obj, scale, 2, 3, 5, lv_color_hex(0xffb1fdf9), -16);
lv_meter_set_scale_range(obj, scale, 0, 60, 270, 135);
lv_meter_indicator_t *indicator = lv_meter_add_needle_line(obj, scale, 4, lv_color_hex(0xffb3faf7), -8);
indicator1 = indicator;
lv_meter_set_indicator_value(obj, indicator, 0);
lv_meter_indicator_t *indicator = lv_meter_add_arc(obj, scale, 14, lv_color_hex(0xff45667d), -8);
indicator2 = indicator;
lv_meter_set_indicator_start_value(obj, indicator, 0);
lv_meter_set_indicator_end_value(obj, indicator, 0);
lv_obj_set_style_min_width(obj, 100, LV_PART_TICKS | LV_STATE_DEFAULT);
lv_obj_set_style_text_color(obj, lv_color_hex(0xffb3faf7), LV_PART_MAIN | LV_STATE_DEFAULT);
lv_obj_set_style_text_font(obj, &lv_font_montserrat_16, LV_PART_MAIN | LV_STATE_DEFAULT);
lv_obj_set_style_radius(obj, 32767, LV_PART_MAIN | LV_STATE_DEFAULT);
lv_obj_set_style_outline_width(obj, 2, LV_PART_MAIN | LV_STATE_DEFAULT);
lv_obj_set_style_outline_color(obj, lv_color_hex(0xffffffff), LV_PART_MAIN | LV_STATE_DEFAULT);
lv_obj_set_style_outline_pad(obj, 0, LV_PART_MAIN | LV_STATE_DEFAULT);
lv_obj_set_style_outline_opa(obj, 100, LV_PART_MAIN | LV_STATE_DEFAULT);
lv_obj_set_style_border_color(obj, lv_color_hex(0xffe0e0e0), LV_PART_MAIN | LV_STATE_DEFAULT);
lv_obj_set_style_border_width(obj, 2, LV_PART_MAIN | LV_STATE_DEFAULT);
lv_obj_set_style_text_opa(obj, 255, LV_PART_MAIN | LV_STATE_DEFAULT);
lv_obj_set_style_transform_width(obj, 5, LV_PART_MAIN | LV_STATE_DEFAULT);
lv_obj_set_style_transform_height(obj, 5, LV_PART_MAIN | LV_STATE_DEFAULT);
