i try to use drop-down list in my project. function lv_dropdown_get_selected( ddlist ) seems invalid in callback funtion. lvgl v7.30
Before posting
masterbranch.- Try to reproduce the issue in a Simulator. If it’s working there then probably it’s not a LittlevGL issue.
What do you experience?
Give a detailed description. “It doesn’t work” is not enough information for us to diagnose the issue.
What do you expect?
Add a code snippet to reproduce the issue in the simulator. It should contain only the relevant code which can be compiled. Bug reports without code snippets or with erroneous code snippets will not be reviewed.
Use the ```c and ``` tags to format your code:
If possible, add screenshots and/or videos about the current issue.
