Before posting
If LVGL does not have the same image size as the image size set by lv_obj_set_size using LV_IMG_DECLARE, do you draw the set image repeatedly to fill it with the size of the image loaded?
The above image size is 50 and the set_size is also 50
The above image size is 50, but the set_size is 128
