Before posting
I have suceessfuly running widget demo of v8.3 lvgl on my embedded linux system with MIPS arch, but the mouse’s cursor and UI are displayed on the same fb0.
But what I want is displaying mouse’s cursor on fb1 and UI on fb0. So I read and updated lvgl with V9.0 for it have better upgrade about framebuffer and lv_display, but I am not sure it’s OK. Please let me know if anybody knows about it, thank you
mips with embedded Linux system
V9.0
Display UI and mouse cursor in different framebuffer
coding
lvgl v9.0
/*Linux frame buffer device init*/
lv_display_t * disp = lv_linux_fbdev_create();
lv_linux_fbdev_set_file(disp, "/dev/fb0");
lv_display_t * cursor_disp = lv_linux_fbdev_create();
lv_linux_fbdev_set_file(cursor_disp, "/dev/fb1");
lv_display_set_default(disp);
/*Create mouse evdev*/
lv_indev_t *mouse = lv_evdev_create(LV_INDEV_TYPE_POINTER, "/dev/input/event0");
lv_indev_set_display(mouse, cursor_disp);
/*Set a cursor for the mouse*/
LV_IMG_DECLARE(mouse_cursor_icon)
lv_obj_t * cursor_obj = lv_img_create(lv_display_get_screen_active(cursor_disp)); /*Create an image object for the cursor */
lv_img_set_src(cursor_obj, &mouse_cursor_icon); /*Set the image source*/
lv_indev_set_cursor(mouse, cursor_obj); /*Connect the image object to the driver*/
/*Create a Demo*/
lv_demo_widgets();
lvgl v8.3
fbdev_init();
/*A small buffer for LittlevGL to draw the screen's content*/
static lv_color_t buf[DISP_BUF_SIZE];
/*Initialize a descriptor for the buffer*/
lv_disp_draw_buf_init(&disp_buf, buf, NULL, DISP_BUF_SIZE);
/*Initialize and register a display driver*/
lv_disp_drv_init(&disp_drv);
disp_drv.hor_res = WIN_HOR_RES;
disp_drv.ver_res = WIN_VER_RES;
evdev_init();
static lv_indev_drv_t indev_drv_1;
lv_indev_drv_init(&indev_drv_1); /*Basic initialization*/
indev_drv_1.type = LV_INDEV_TYPE_POINTER;
/*This function will be called periodically (by the library) to get the mouse position and state*/
indev_drv_1.read_cb = evdev_read;
lv_indev_t *mouse_indev = lv_indev_drv_register(&indev_drv_1);
lv_obj_t * cursor_obj = lv_img_create(lv_scr_act()); /*Create an image object for the cursor */
lv_indev_set_cursor(mouse_indev, cursor_obj); /*Connect the image object to the driver*/
/*Create a Demo*/
lv_demo_widgets();
