Before posting
master branch.
- Be sure you have checked the FAQ and read the relevant part of the documentation.
When I change a switch state,there is a mistake display
STM32H750
LVGL 9.3
I have try to display a cont. Its OK
lv_obj_t* screen = lv_obj_create(NULL);
lv_screen_load(screen);
//static lv_style_t style_rect;
//lv_style_init(&style_rect);
//lv_style_set_bg_color(&style_rect, lv_color_hex(0xFF0000)); // 红色
//lv_obj_t * rect = lv_obj_create(lv_scr_act());
//lv_obj_add_style(rect, &style_rect, 0);
//lv_obj_set_size(rect, 300, 200);
lv_obj_t* sw = lv_switch_create(screen);
lv_obj_set_size(sw, 300, 200);
lv_obj_add_state(sw,LV_STATE_CHECKED);
Please share your flush_cb. Probably there is an off by one issue there is width calculation.
OK.This is the flush code.
static void disp_flush(lv_display_t * disp_drv, const lv_area_t * area, uint8_t * px_map) {
int32_t width = area->x2 - area->x1 + 1;
int32_t height = area->y2 - area->y1 + 1;
uint32_t line_offset = (MY_DISP_HOR_RES - width); // Display stride adjustment
uint32_t fb_addr = 0xD0000000 + (MY_DISP_HOR_RES * area->y1 + area->x1) * 2; // FB address calculation
// Clean CPU cache to ensure data coherence
SCB_CleanDCache_by_Addr((uint32_t*)px_map, width * height * 2); // RGB565=2 bytes/pixel
// Invoke DMA2D copy
_DMA2D_Copy((uint32_t*)px_map, (void*)fb_addr, width, height, 0, line_offset);
lv_display_flush_ready(disp_drv); // Critical: Notify LVGL flush completion
void _DMA2D_Copy(void *pSrc, void *pDst, uint32_t xSize, uint32_t ySize, uint32_t SrcOffset, uint32_t DstOffset) {
// Configure DMA2D for Memory-to-Memory (RGB565)
DMA2D->CR = 0x00000000UL | (1 << 9); // Mode: Memory-to-memory
DMA2D->FGMAR = (uint32_t)pSrc; // Source address
DMA2D->OMAR = (uint32_t)pDst; // Destination address
DMA2D->FGOR = SrcOffset; // Source line offset
DMA2D->OOR = DstOffset; // Destination line offset
DMA2D->FGPFCCR = LTDC_PIXEL_FORMAT_RGB565; // Input format
DMA2D->OPFCCR = LTDC_PIXEL_FORMAT_RGB565; // Output format
DMA2D->NLR = (xSize << 16) | ySize; // Set region size (width/height)
// Invalidate cache for destination before DMA transfer
SCB_InvalidateDCache_by_Addr(pDst, xSize * ySize * 2);
// Start blocking transfer
DMA2D->CR |= DMA2D_CR_START;
while (DMA2D->CR & DMA2D_CR_START) {} // Wait until completion
I have tried other widgets, such as Label. It looks normal. The switch looks normal too before it changes state. But once it changes its state, it looks wrong.
Try correct this
i mean you miss here
Do you mean this? I used it if I am right, but it is not useful.
x = area->x2 - area->x1 +1;
y = area->y2 - area->y1 +1;
uint32_t addr = (0xD0000000 + (MY_DISP_HOR_RES*area->y1 + area->x1)2);
// Clean CPU cache to ensure data coherence |
|SCB_CleanDCache_by_Addr((uint32_t)px_map, width * height * 2); // RGB565=2 bytes/pixel |
it will be easier to read your code if you wrap it in triple back ticks.
Some code
It comes out
Some code
I’m sorry, I’m new to the forum and don’t fully understand some of the procedures. I’ll fix it.
int32_t x;
int32_t y;
// uint32_t OffLineDst = (MY_DISP_HOR_RES - (area->x2 - area->x1 +1));
uint32_t addr = (0xD0000000 + (MY_DISP_HOR_RES*area->y1 + area->x1)*2);
(void *)addr,
x,
y,
0,
line_offset) ;
/*IMPORTANT!!!
*Inform the graphics library that you are ready with the flushing*/
void _DMA2D_Copy(void * pSrc,
void * pDst,
uint32_t xSize,
uint32_t ySize,
uint32_t OffLineSrc,
uint32_t OffLineDst)
// Calculate buffer size for RGB565 format (2 bytes per pixel)
uint32_t bufferSize = xSize * ySize * 2;
// Clean CPU cache to ensure data is written to physical memory [4,5](@ref)
SCB_CleanDCache_by_Addr(pSrc, bufferSize);
/* Configure DMA2D in memory-to-memory mode (foreground layer as input) */
DMA2D->CR = 0x00000000UL | (1 << 9); // Set bit 9 for register-to-memory mode
DMA2D->FGMAR = (uint32_t)pSrc; // Set source memory address
DMA2D->OMAR = (uint32_t)pDst; // Set destination memory address
DMA2D->FGOR = OffLineSrc; // Source line offset (pixels)
DMA2D->OOR = OffLineDst; // Destination line offset (pixels)
/* Set color format for foreground layer and output to RGB565 */
DMA2D->FGPFCCR = LTDC_PIXEL_FORMAT_RGB565; // Input format: RGB565
DMA2D->OPFCCR = LTDC_PIXEL_FORMAT_RGB565; // Output format: RGB565
// Configure image dimensions: NLR[31:16]=xSize, NLR[15:0]=ySize
DMA2D->NLR = (uint32_t)(xSize << 16) | (uint16_t)ySize;
// Invalidate D-Cache before starting transfer for data consistency [4](@ref)
SCB_InvalidateDCache_by_Addr(pDst, bufferSize);
/* Initiate DMA2D transfer */
DMA2D->CR |= DMA2D_CR_START; // Set START bit
/* Poll until transfer completes */
while (DMA2D->CR & DMA2D_CR_START) {} // Wait for START bit to clear
When I try to use “Two buffers screen sized buffer for double buffering”, the widget disappears after changing state.
I suggest trying out LVGL’s buil in DMA2D implementation: lvgl/src/draw/dma2d at master · lvgl/lvgl · GitHub
I tried it but it displayed another error.
! Adding padding to the parent container surprisingly resolved clipping issues for most edge-positioned child widgets. However, the Arc widget (lv_arc) still exhibits rendering artifacts after interaction—even when scaled down (e.g., 50% smaller) and positioned centrally within the padded area. Specific observations:
- Artifacts occur during knob adjustment (e.g., jagged indicator lines or partial redraw errors).
Would this imply an Arc-specific edge-case in the rendering pipeline? Any debugging directions would be invaluable.
arc_set_hb = lv_arc_create(con_pre_set_2);
lv_obj_update_layout(con_pre_set_2);
lv_coord_t parent_h = lv_obj_get_height(con_pre_set_2);
lv_obj_set_size(arc_set_hb, 0.2*parent_h, 0.2*parent_h);
lv_obj_align_to(arc_set_hb, lab_set_hb_num, LV_ALIGN_OUT_RIGHT_MID, 10, 10);
lv_arc_set_range(arc_set_hb,Pulse_MIN,Pulse_MAX);
lv_arc_set_value(arc_set_hb, Pulse_NUM);
