Before posting
how to create defined number of an object as a child on a panel as parrent. based on lvgl library the output of lv_label_create function is (lv_obj_t *). I want to create N number of Lables after the N was Defined. but using the below code results to Hardfault.
stm32g769igt6
V8.2
how to define a N number of an object (lable in my case) in a for loop function
the below code
/* uint16_t NumberOfAlarms = 5;
lv_obj_t ** AlarmsLable_OBJ;
lv_obj_t ** AlarmsType_OBJ;
for(uint8_t i = 0; i < NumberOfAlarms; i++){
*(AlarmsLable_OBJ + i) = lv_label_create(ui_ParamAlarmsChildPanel);
lv_obj_set_width(*(AlarmsLable_OBJ + i), LV_SIZE_CONTENT); /// 1
lv_obj_set_height(*(AlarmsLable_OBJ + i), LV_SIZE_CONTENT); /// 1*/
