Before posting
masterbranch.- Be sure you have checked the relevant part of the documentation.
I want to do some cooperation between textarea and keyboard, such as when click textarea, it shows keyboard, then when I clicked the LV_SYMBOL_KEYBOARD hide the keyboard and the textarea cursor. I found some problems in my code.
1、how to hide textarea cursor? It’s not so convenient compare with V6.0.2
2、If I simply create a keyboard, then I clicked the LV_SYMBOL_KEYBOARD, it can’t hide the keyboard.
3、In my code, ta_event_cb. When I try to debug my code, once I clicked the textarea, It seems to run it in ta_event_cb again and again, but the lv_event_code_t code is different everytime.
4、If I add textarea through LV_EVENT_CLOSE not through LV_EVENT_ALL,then I found if I click one textarea, the keyboard will close, then I clicked this textarea again, it will not run into ta_event_cb again, when I click another textaren it run it in ta_event_cb again.
ARM335X
V8.0.2
static void ta_event_cb(lv_event_t * e)
lv_obj_t * ta = lv_event_get_target(e);
if(code == LV_EVENT_CLICKED || code == LV_EVENT_FOCUSED) {
/*Focus on the clicked text area*/
if(g_keyboard != NULL)
lv_obj_clear_flag(g_keyboard, LV_OBJ_FLAG_HIDDEN);
lv_keyboard_set_textarea(g_keyboard, ta);
else if(code == LV_EVENT_READY) {
LV_LOG_USER("Ready, current text: %s", lv_textarea_get_text(ta));
static void KeyboardEventCB(lv_event_t* event)
// lv_keyboard_def_event_cb(event);
// lv_obj_t* ta_of_kb = lv_keyboard_get_textarea(g_keyboard);
if(code == LV_EVENT_CANCEL)
// lv_textarea_t * ta = (lv_textarea_t *)ta_of_kb;
// ta->cursor.show = 0;
lv_obj_add_flag(g_keyboard, LV_OBJ_FLAG_HIDDEN);
void CreateKeyboard(lv_obj_t* parent, lv_coord_t w, lv_coord_t h)
g_keyboard = lv_keyboard_create(parent);
lv_obj_set_size(g_keyboard, w, h);
lv_obj_align_to(g_keyboard, parent, LV_ALIGN_BOTTOM_RIGHT, 0, 0);
// lv_obj_add_event_cb(g_keyboard, KeyboardEventCB, LV_EVENT_CANCEL, NULL);
// lv_obj_add_flag(g_keyboard, LV_OBJ_FLAG_HIDDEN);
int main()
CreateKeyboard(lv_scr_act(), 940, 150);
lv_obj_t * text_ta = lv_textarea_create(lv_scr_act());
lv_textarea_set_one_line(text_ta, true);
lv_textarea_set_password_mode(text_ta, false);
lv_obj_set_width(text_ta, lv_pct(40));
lv_obj_add_event_cb(text_ta, ta_event_cb, LV_EVENT_ALL, NULL);
lv_obj_align_to(text_ta, NULL, LV_ALIGN_TOP_LEFT, 0, 60);
lv_obj_t * text_ta1 = lv_textarea_create(lv_scr_act());
lv_textarea_set_one_line(text_ta1, true);
lv_textarea_set_password_mode(text_ta1, false);
lv_obj_set_width(text_ta1, lv_pct(40));
lv_obj_add_event_cb(text_ta1, ta_event_cb, LV_EVENT_ALL, NULL);
lv_obj_align_to(text_ta1, NULL, LV_ALIGN_TOP_RIGHT, 0, 60);
