Before posting
I have some labels in an array and I want to be able to determine which symbol is being displayed by any element by comparing.
STM32L4R5ZIVT / VisualGDB
7.9
HI,
I would like a function that can be passed a symbol i.e. LV_SYMBOL_BLUETOOTH and then iterate through the array of labels with lv_label_get_text and then do something like a strcmp() to compare the two.
char * labelText = lv_label_get_text(labelObj);
if (strcmp(symbol, labelText) == 0 )
location = i;
There is never a match between the symbol and the text from the label, even when they are the same
