Cmake Examples, Demos, and Thorvg always building
I implemented lvgl v9.0.0 into my cmake project. The following is my cmake code. It seems to build fine but it always builds the examples, demo, and thorvg even when I have the defines to disable them in lv_conf.h.
# LVGL ---------------------------------------------------------------------------------------------
# Specify path to own LVGL config header
set(LV_CONF_PATH
    ${CMAKE_CURRENT_SOURCE_DIR}/../App/lv_conf.h
    CACHE STRING "" FORCE)
message("LVGL Conf Path: " ${LV_CONF_PATH})
set(LV_VERSION "v9.0.0") # this string represents the Tag name of the release desired - Change the GIT_TAG below as well
message("Fetching LVGL " ${LV_VERSION})
# Fetch lvgl
FetchContent_Declare(
  lvgl
  GIT_REPOSITORY https://github.com/lvgl/lvgl
  GIT_TAG       v9.0.0
FetchContent_MakeAvailable(
  lvgl
target_compile_definitions(lvgl PRIVATE
   # Add user defined symbols
   LV_CONF_BUILD_DISABLE_EXAMPLES
   LV_CONF_BUILD_DISABLE_DEMOS
message("Fetching LVGL Done")
target_link_libraries(${CMAKE_PROJECT_NAME}
   stm32cubemx
   lvgl::lvgl
   # Add user defined libraries
Inside lv_conf.h
#define LV_CONF_BUILD_DISABLE_EXAMPLES 1
#define LV_CONF_BUILD_DISABLE_DEMOS 1
#define LV_CONF_BUILD_DISABLE_THORVG_INTERNAL 1
STM32 with Cmake. I followed this page for setup: STM32 — LVGL documentation
v9.0.0
Find out why my defines are not changing the build instructions.
Putting the defines in the CMakeList.txt and inside lv_conf.h. I also found this forum post here: Disabling LV_BUILD_EXAMPLES in lv_conf.h but still it gets build
but they changed it inside env_support/cmake/custom.cmake. Where the docs say to fetchcontent and therefore I dont have access to env_support/cmake/custom.cmake.
Code above
I reverted to v8.4.0 and the LV_BUILD_EXAMPLES actually effects it. Setting it to 0, it then doesnt build the examples.
