Before posting
STM32F103
Chinese display
used lv_font_simsum_16_cjk * Also cannot display Chinese, * * But everything else is displayed normally. * * Is there a problem with the Chinese character database? * What does this need to change? “lv_conf.h”
myFont.txt (5.5 KB)
