Before posting
masterbranch.- Be sure you have checked the relevant part of the documentation.
hey, I run the chart demo Display 1000 data points with zooming and scrolling in my device and it works well. Then I think how about enlage the data points. So I want to display 30000 data points by modify the demo code lv_example_chart_5. Then I found that when I scroll the chart(not the slider below), it worked well. But when I scroll the slider, the chart is not shown successfully when the slider is in the 1/3 range. Is there something attributes wrong I setted ?
TI ARM335X
8.0.1
#define POINTNUM 30000
/*chart_point is an array contains 30000 points*/
void lv_example_chart_5(void)
/*Create a chart*/
chart = lv_chart_create(lv_scr_act());
lv_obj_set_size(chart, 900, 150);
lv_obj_align(chart, LV_ALIGN_CENTER, 0, 0);
lv_chart_set_range(chart, LV_CHART_AXIS_PRIMARY_Y, -1000, 1000);
/*Do not display points on the data*/
lv_obj_set_style_size(chart, 0, LV_PART_INDICATOR);
lv_chart_series_t * ser = lv_chart_add_series(chart, lv_palette_main(LV_PALETTE_RED), LV_CHART_AXIS_PRIMARY_Y);
uint32_t pcnt = sizeof(chart_point) / sizeof(chart_point[0]);
lv_chart_set_point_count(chart, pcnt);
lv_chart_set_ext_y_array(chart, ser, (lv_coord_t *)chart_point);
lv_obj_t * slider;
slider = lv_slider_create(lv_scr_act());
lv_slider_set_range(slider, LV_IMG_ZOOM_NONE, POINTNUM);
lv_obj_add_event_cb(slider, slider_x_event_cb, LV_EVENT_VALUE_CHANGED, NULL);
lv_obj_set_size(slider, 900, 10);
lv_obj_align_to(slider, chart, LV_ALIGN_OUT_BOTTOM_MID, 0, 20);
