Before posting
How to change the size of text area of a spinbox? by changing the size of spinbox, just size of spinbox changed but it’s text size didnt effect! how to increase the text size after increasing the spinbox size?
on simulator
V8.2.2
changing the size of spinbox with it’s text area
lv_obj_set_style_text_font(spinbox, LV_FONT_MONTSERRAT_30, LV_PART_INDICATOR);
/*void lv_example_spinbox_1(void)
spinbox = lv_spinbox_create(lv_scr_act());
lv_spinbox_set_range(spinbox, -1000, 25000);
lv_spinbox_set_digit_format(spinbox, 5, 2);
lv_spinbox_step_prev(spinbox);
lv_obj_set_width(spinbox, 300);
lv_obj_set_height(spinbox, 300);
lv_obj_center(spinbox);
lv_coord_t h = lv_obj_get_height(spinbox);
lv_obj_t * btn = lv_btn_create(lv_scr_act());
lv_obj_set_size(btn, h, h);
lv_obj_align_to(btn, spinbox, LV_ALIGN_OUT_RIGHT_MID, 5, 0);
//lv_obj_set_style_bg_img_src(btn, LV_SYMBOL_PLUS, 0);
lv_obj_set_style_bg_img_src(btn, LV_SYMBOL_RIGHT, 0);
lv_obj_add_event(btn, lv_spinbox_increment_event_cb, LV_EVENT_ALL, NULL);
lv_obj_align_to(btn, spinbox, LV_ALIGN_OUT_LEFT_MID, -5, 0);
//lv_obj_set_style_bg_img_src(btn, LV_SYMBOL_MINUS, 0);
lv_obj_set_style_bg_img_src(btn, LV_SYMBOL_OK, 0);
lv_obj_add_event(btn, lv_spinbox_decrement_event_cb, LV_EVENT_ALL, NULL);
If possible, add screenshots
and/or videos about the current state.
