Change Led Style
Before posting
  • Read the
according to documentation:
LEDs are rectangle (or circle) type objects. It’s brightness can be adjusted. With lower brightness, the colors of the LED become darker.
how to change the style of the led to rectangle?
STM32
void lv_ex_led_1(void)
    /*Create a LED and switch it OFF*/
    lv_obj_t * led1  = lv_led_create(lv_scr_act(), NULL);
    lv_obj_align(led1, NULL, LV_ALIGN_CENTER, -80, 0);
    lv_led_off(led1);
    /*Copy the previous LED and set a brightness*/
    lv_obj_t * led2  = lv_led_create(lv_scr_act(), led1);
    lv_obj_align(led2, NULL, LV_ALIGN_CENTER, 0, 0);
    lv_led_set_bright(led2, 190);
    /*Copy the previous LED and switch it ON*/
    lv_obj_t * led3  = lv_led_create(lv_scr_act(), led1);
    lv_obj_align(led3, NULL, LV_ALIGN_CENTER, 80, 0);
    lv_led_on(led3);
You change its radius to 0 to make it a rectangle.
Is it enough to call lv_obj_set_style_local_radius(led1, LV_LED_PART_MAIN, LV_STATE_DEFAULT, 0);?
Yes; that should work.
Maybe it would be useful to add a rectangular LED in the example. I can send a PR if you agree.
Why not? More examples are always good. :slight_smile:
Thank you!
How can you change the led color? The implicit color is red, so i would like to add 2 more for green and blue colors.
Thanks!
You can change the bg_color, border_color, and shadow_color styles of the LED.
The theme might be a good reference implementation to work with, though you shouldn’t need to change every single property in that function, just the ones I mentioned above.
Thanks, it worked!
