Change appearance of selected options in dropbox and menu widget
Before posting
Fairly new to LVGL; but have managed to get latest (Apr. '22) github version (8.2+) running under Arduino on the WIO Terminal. Still exploring widgets and trying to get a handle on the underlying mechanisms for styles in various widgets (e.g. lists, tables, etc.).
Have been running some of the example codes (from Examples | LVGL Open) on this port. I do not have a touch screen, so have been working with a 5-way keypad switch. Dropbox and menu examples appear to run correctly; but selected options are not highlighted with a background blue color. They remain as black text on a white background like other options. The selected lines do have their font slightly changed - not enough for most users, but I can see it. So, things are mostly behaving as expected. My question is how to change the example code to affect background color for the selected option/button. I assume the answer is in the style system, but it’s not obvious - to me – how to change styles for the internal elements of some of these widgets.
Any pointers would be appreciated. I can include code/details; but most of it is specific to setting up my WIO LCD port and the remainder is code literally pasted from the web site.
Regards,
rtisys
You can do it like this:
    lv_obj_set_style_bg_color(lv_dropdown_get_list(dd), lv_color_hex(0xff0000), LV_PART_SELECTED | LV_STATE_CHECKED);
