esp32s3 with arduino
v8.3
Show a jpg or sjpg img saved on sd card
I have tired the code below to check lvgl can read the file inside my sd card, result is output “Open OK”
void lv_fs_test(void)
lv_fs_file_t f;
lv_fs_res_t res;
res = lv_fs_open(&f, "S:readme.txt", LV_FS_MODE_RD);
if(res != LV_FS_RES_OK)
Serial.println("Open fail");
Serial.println("Open OK");
In lv_conf.h:
/* JPG + split JPG decoder library.
* Split JPG is a custom format optimized for embedded systems. */
#define LV_USE_SJPG 1
#define LV_USE_FS_FATFS 1
#if LV_USE_FS_FATFS
#define LV_FS_FATFS_LETTER 'S' /*Set an upper cased letter on which the drive will accessible (e.g. 'A')*/
void lvglSetup(){
// Init Display
gfx->begin();
pinMode(TFT_BL, OUTPUT);
digitalWrite(TFT_BL, HIGH);
gfx->fillScreen(RED);
delay(100);
gfx->fillScreen(GREEN);
delay(100);
gfx->fillScreen(BLUE);
delay(100);
gfx->fillScreen(BLACK);
delay(50);
delay(10);
screenWidth = gfx->width();
screenHeight = gfx->height();
disp_draw_buf1 = (lv_color_t *)heap_caps_malloc(sizeof(lv_color_t) * screenWidth * screenHeight / 8, MALLOC_CAP_INTERNAL | MALLOC_CAP_8BIT);
disp_draw_buf2 = (lv_color_t *)heap_caps_malloc(sizeof(lv_color_t) * screenWidth * screenHeight / 8, MALLOC_CAP_INTERNAL | MALLOC_CAP_8BIT);
lv_disp_draw_buf_init(&draw_buf, disp_draw_buf1, disp_draw_buf2, screenWidth * screenHeight / 8);
/* Initialize the display */
lv_disp_drv_init(&disp_drv);
/* Change the following line to your display resolution */
lv_obj_set_style_bg_color(lv_scr_act(), lv_color_hex(0x000000),LV_STATE_DEFAULT );
lv_obj_set_style_bg_opa(lv_scr_act(), 255, LV_STATE_DEFAULT);
Serial.println("Setup done");
After the initialization of display, lvgl works cause the CPU usage and FPS count are shown.
In setup (SD card initialization omitted due to insignificance.):
void setup() {
lvglSetup();
lv_fs_fatfs_init();
lv_fs_test();
lv_obj_t *img= lv_img_create(lv_scr_act());
lv_split_jpeg_init();
lv_img_set_src(img, "S:icons/bilibili.sjpg");
lv_obj_set_style_bg_opa(img, 255, LV_STATE_DEFAULT);
lv_obj_align(img, LV_ALIGN_CENTER, 0, 0);
Serial.println("Icon showed");
Result till now
CPU usage and FPS count are shown → lvgl runs success
lv_fs_test() fuction give positive result → lvgl can read file inside my sd card
I don’t know what to do next? No idea where i missed, cause LV_SYMBOL can be shown
lv_img_set_src(img, LV_SYMBOL_OK);
