I have the following code that should scroll though a drop-down with UP/DOWN actions, and ENTER should select the item. However, only the DOWN button kind-of works – after a single press, it scrolls through the whole list. No other buttons work, although in the REPL I can see the button presses:
Button read [<Button object at 3f81e7e0>] (struct lv_indev_drv_t) state: 1, key:10, id:2
State change [Pin(19)] True->False [10]
Button read [<Button object at 3f81e7e0>] (struct lv_indev_drv_t) state: 0, key:10, id:2
State change [Pin(19)] False->True [10]
State change [Pin(18)] True->False [17]
Button read [<Button object at 3f81e7d0>] (struct lv_indev_drv_t) state: 0, key:17, id:1
State change [Pin(18)] False->True [17]
Button read [<Button object at 3f81e7d0>] (struct lv_indev_drv_t) state: 1, key:10, id:1
State change [Pin(23)] True->False [18]
Button read [<Button object at 3f81e810>] (struct lv_indev_drv_t) state: 0, key:18, id:3
State change [Pin(23)] False->True [18]
Button read [<Button object at 3f81e810>] (struct lv_indev_drv_t) state: 1, key:10, id:3
Any ideas what could be the problem?
main.py
import ili9XXX
import espidf as esp
import lvgl as lv
from machine import Pin
from utils import Button
from micropython import const
lv.init()
from ili9XXX import ili9488
disp = ili9488(miso=14, mosi=15, clk=4, cs=25, dc=26, rst=27, power=14, backlight=-1, backlight_on=0, power_on=0,
spihost=esp.VSPI_HOST, mhz=50, factor=16, hybrid=True, width=480, height=320, invert=False,
double_buffer=True, half_duplex=False, initialize=True, rot=ili9XXX.LANDSCAPE)
BUTTON_A_PIN = const(18)
BUTTON_B_PIN = const(19)
BUTTON_C_PIN = const(23)
# Create a normal drop down list
dd = lv.dropdown(lv.scr_act())
dd.set_options("\n".join([
"Apple",
"Banana",
"Orange",
"Cherry",
"Grape",
"Raspberry",
"Melon",
"Orange",
"Lemon",
"Nuts"]))
dd.align(lv.ALIGN.TOP_MID, 0, 20)
# Constructs the button reader
def button_read_constr(*btns):
def button_read(drv, data):
for btn in btns:
press = btn.pressed
if press:
data.state = lv.INDEV_STATE.PRESSED
else:
data.state = lv.INDEV_STATE.RELEASED
data.key = btn.key
data.btn_id = btn.id
if btn.changed:
print("Button read [{}] ({}) state: {}, key:{}, id:{}".format(btn, drv, data.state, data.key, data.btn_id))
return False
return button_read
button_a = Button(Pin(BUTTON_A_PIN), id=1, key=lv.KEY.UP)
button_b = Button(Pin(BUTTON_B_PIN), id=2, key=lv.KEY.ENTER)
button_c = Button(Pin(BUTTON_C_PIN), id=3, key=lv.KEY.DOWN)
read_button = button_read_constr(button_a, button_b, button_c)
indev_drv = lv.indev_drv_t()
indev_drv.type = lv.INDEV_TYPE.ENCODER
indev_drv.read_cb = read_button
win_drv = indev_drv.register()
group = lv.group_create()
group.add_obj(dd)
win_drv.set_group(group)
while True:
pass
utils.py
from input import DigitalInput
class Button:
def __init__(self, pin, id, key):
self._press = False
self._changed = False
self._id = id
self._key = key
self.setPin(pin)
def _cb(self, pin, press):
if self._press != press:
print("State change [{}] {}->{} [{}]".format(pin, self._press, press, self._key))
self._changed = True
self._press = press
@property
def pressed(self):
return self._press
@property
def changed(self):
ch = self._changed
return ch
@property
def id(self):
return self._id
@property
def key(self):
return self._key
def setPin(self, pin):
# DigitalIput : the class that monitors/debounces pin. Uses an irq internally
# see : https://github.com/tuupola/micropython-m5stack/blob/master/firmware/lib/input.py
# Can be replaced with an explicit irq on the pin object.
self._input = DigitalInput(pin, self._cb)
Thanks,
Jerry
