Before posting
the bar’s anim dose’t work.
LVGL simulator with VS2019.
V8.3.5
set the bar’s value with anim.
if i uselv_bar_set_val(bar,val,LV_ANIM_ON),it could set the value right whithout anim.
so i try the examplelv_example_bar_6,it’s worked right. i want to know what’s the prablem.
