Before posting
I am using LVGL v8.3 and trying to draw bar chart using Chart widget ( lv_chart ).
Currently using only 1 series with 2 data points and these data points are updated in runtime.
I am also setting the maximum height and width using lv_obj_set_size.
How to draw the always border to individual bar which is equivalent to max height of the bar irrespective the data point value.
S
8.3
Draw the color border to individual bar irrespective the data point value
Tried to set the border in callback function static void draw_event_cb(lv_event_t * e). However, border is draw only till the value of data point and not the always maximum height of the bar. Here border is automatically adjusted against the current data point value in series.
// Set border properties for each bar
dsc->rect_dsc->border_width = 2; // Set border width as needed
dsc->rect_dsc->border_color = lv_color_black(); // Set border color
dsc->rect_dsc->border_side = LV_BORDER_SIDE_FULL; // Border on all sides
