Before posting
version:LVGL8.10
colorwheel use the lv_colorwheel_set_hsv
In LV_COLORWHEEL_MODE_SATURATION mode. Change Hue by pressing btn.
The knob’color changes right, but its main color does not change.
v8.1.0-dev
Compared version 7.10 and version 8.10, version 7.10 is OK, and I don’t know why version 8.10 can’t be implemented.
lv_obj_t* cw;
uint16_t Test;
static void event_handler(lv_event_t* e)
if (code == LV_EVENT_CLICKED) {
LV_LOG_USER(“Clicked”);
lv_color_hsv_t hsv_cur;
if (Test < 360)
Test = Test + 10;
Test = 0;
hsv_cur.h = Test;
hsv_cur.s = 100;
hsv_cur.v = 100;
lv_colorwheel_set_hsv(cw, hsv_cur);
void lv_example_colorwheel_1(void)
cw = lv_colorwheel_create(lv_scr_act(), true);
lv_obj_set_size(cw, 240, 240);
lv_obj_center(cw);
lv_colorwheel_set_mode(cw, LV_COLORWHEEL_MODE_SATURATION);
lv_obj_t* btn1 = lv_btn_create(lv_scr_act());
lv_obj_add_event_cb(btn1, event_handler, LV_EVENT_CLICKED, NULL);
lv_obj_align(btn1, LV_ALIGN_CENTER, 0, 0);
lv_obj_set_size(btn1, 40, 40);
