Before posting
Based on Lvgl 6.0, I created a group and added four image objx. After initialization, everything works fine, but when the encoder is rotated, the previously pointed object is not refreshed.
After normal initialization. It is shown as follows:
After rotating the encoder, it is shown as follows:
STM32F303xx
Why the previously pointed object is not refreshed? and how to fix it?
I tried to create four simple buttons and everything worked fine.
void main_desk(void)
/*use night theme */
// lv_theme_set_current(lv_theme_night_init(MYHUE,NULL));
main_group=lv_group_create();
/*Add encode to control the list */
lv_indev_drv_t enc_drv;
lv_indev_drv_init(&enc_drv);
enc_drv.type = LV_INDEV_TYPE_ENCODER;
enc_drv.read_cb = encode_read;
lv_indev_t * enc_indev = lv_indev_drv_register(&enc_drv);
lv_indev_set_group(enc_indev, main_group);
/*create a win */
static lv_style_t win_style;
lv_style_copy(&win_style, &lv_style_pretty);
// win_style.body.main_color=LV_COLOR_BLACK;
win_style.image.color=LV_COLOR_GREEN;
win_style.body.padding.left= 50;
win_style.body.padding.right = 50;
win_style.body.padding.inner = 35;
mian_win = lv_win_create(lv_disp_get_scr_act(NULL), NULL);
lv_win_set_layout(mian_win,LV_LAYOUT_GRID);
lv_win_set_style(mian_win, LV_WIN_STYLE_CONTENT, &win_style);
// lv_obj_set_size(mian_win, LV_HOR_RES_MAX, LV_VER_RES_MAX);
lv_win_set_title(mian_win,"");
lv_win_add_btn(mian_win,LV_SYMBOL_POWER);
lv_win_add_btn(mian_win,LV_SYMBOL_BATTERY_FULL);
LV_IMG_DECLARE(Wave);
LV_IMG_DECLARE(Battery);
LV_IMG_DECLARE(Power);
LV_IMG_DECLARE(Settings);
lv_obj_t * Power_img = lv_img_create(mian_win, NULL);
lv_img_set_src(Power_img,&Power);
// lv_obj_set_pos(Power_img,65,25);
lv_group_add_obj(main_group,Power_img);
lv_obj_set_event_cb(Power_img,list_btn_event_handler);
lv_obj_t * Wave_img = lv_img_create(mian_win, NULL);
lv_img_set_src(Wave_img,&Wave);
// lv_obj_set_pos(Wave_img,198,25);
lv_group_add_obj(main_group,Wave_img);
lv_obj_set_event_cb(Wave_img,list_btn_event_handler);
lv_obj_t * Battery_img = lv_img_create(mian_win, NULL);
lv_img_set_src(Battery_img,&Battery);
// lv_obj_set_pos(Battery_img,65,122);
lv_group_add_obj(main_group,Battery_img);
lv_obj_set_event_cb(Battery_img,list_btn_event_handler);
lv_obj_t * Settings_img = lv_img_create(mian_win, NULL);
lv_img_set_src(Settings_img,&Settings);
// lv_obj_set_pos(Settings_img,198,122);
lv_group_add_obj(main_group,Settings_img);
lv_obj_set_event_cb(Settings_img,list_btn_event_handler);
