Ssd1963(800x480) lvgl very slow
Before posting
stm32f407 disco cubeide
lvgl 9
ssd1963(800x480) high fps on lvgl
fsmc+dma
I moved stm32f407 discovery,ssd1963(800x480) lvgl. I am using fsmc+dma. Lvgl is very slow.
#define LV_MEM_SIZE (48U * 1024U)
#define FB_SIZE 10
void LV_tft_init(void)
static lv_color_t buf_1[ SSD1963_SCREEN_WIDTH * FB_SIZE];
     static lv_color_t buf_2[ SSD1963_SCREEN_WIDTH * FB_SIZE];
lv_disp_draw_buf_init(&disp_buf, buf_1,buf_2,SSD1963_SCREEN_WIDTH * FB_SIZE);
lv_disp_drv_init(&disp_drv);
disp_drv.flush_cb = tft_flush_cb;
disp_drv.monitor_cb = monitor_cb;
disp_drv.hor_res = 800;
disp_drv.ver_res = 480;
//disp_drv.sw_rotate = 1;//SCREEN
//disp_drv.rotated = LV_DISP_ROT_180;
static void tft_flush_cb(lv_disp_drv_t * drv, const lv_area_t * area, lv_color_t * color_p)
int32_t act_x2 = area->x2 > SSD1963_SCREEN_WIDTH - 1 ? SSD1963_SCREEN_WIDTH - 1 : area->x2;
int32_t act_y2 = area->y2 > SSD1963_SCREEN_HEIGHT - 1 ? SSD1963_SCREEN_HEIGHT - 1 : area->y2;
x1_flush = act_x1;
y1_flush = act_y1;
x2_flush = act_x2;
y2_flush = act_y2;
y_flush_act = act_y1;
buf_to_flush = color_p;
/*Use DMA instead of DMA2D to leave it free for GPU*/
HAL_StatusTypeDef err;
      SSD1963_Set_Address(x1_flush, y_flush_act, x2_flush, y_flush_act + 1);
err = HAL_DMA_Start_IT(&hdma_memtomem_dma2_stream0,(uint32_t)buf_to_flush, (uint32_t)lcdAddr, (x2_flush - x1_flush + 1));
if(err != HAL_OK)
while(1);
I made #define LV_MEM_SIZE (48U * 1024U) ,60U
#define FB_SIZE I did 10 .30, nothing changed.
lvgl is still very slow, what should I do to speed it up?
ssd1963.zip (933.9 KB)
What is clock speed of FSMC?
FB_SIZE should be at least 48. (Usually I recommend 1/10 screen sized buffer)
FSMC init
Timing.AddressSetupTime = 15;
Timing.AddressHoldTime = 15;
Timing.DataSetupTime = 255;
FB_SIZE 48
// static lv_color_t buf_2[ SSD1963_SCREEN_WIDTH * FB_SIZE];
lv_disp_draw_buf_init(&disp_buf, buf_1,NULL,SSD1963_SCREEN_WIDTH * FB_SIZE);
no change
I changed the values of fsmc, still the same,
FB_SIZE 48
FB_SIZE 70 is still the same
ram overflow when FB_SIZE becomes 80
I did FB_SIZE 35. Because ram is limited, I doubled the buffer. Still slow, screen refresh is obvious. What is my maximum speed with this hardware, what should I do for faster screen refresh.
