Can you know how to not mark if one variable on the chart is zero?
Before posting
zephyr/nrf52
maybe 8.2
If the variable value in the chart is 0, I hope it will not be marked.
Now, it is indicated as a picture and is experiencing inconvenience.
lv_chart_set_range (chart2, lv_chart_axis_primary_y, 0, 30);
I tried to raise the min, but it wasn’t what I wanted.
lv_chart_set_range(chart2, LV_CHART_AXIS_PRIMARY_Y, 0, 30);
lv_chart_set_next_value(chart2, ser2, 0);
lv_chart_set_next_value(chart2, ser2, 10);
I do not speak English so that grammar and words can be a lot wrong. sorry.
Thank you in advance
You can set that point’s value to LV_CHART_POINT_NONE.
Thank you for always. :+1:
I couldn’t find it in the documents. :sweat_smile:
When it is displayed as ui, it is displayed as -nan, but we will find a solution later.
Great! In the docs you can find it here:
https://docs.lvgl.io/master/widgets/chart.html#modify-the-data
Oh! thank you
I need to improve my self-reading skills. :sweat_smile:
Done worry, I also have a kind of “reading-blindness”. Especially when I need to read the texts I have written. :smiley:
