Zoom image and keep same dimensions
I have an image displayed on my screen and I would like to zoom in. When I zoom in, the image scales up but it changes the dimensions of the image, so a bigger part of the screen is covered by the image.
But I would like to keep the same dimensions as before the zoom and cover the same part of the screen but with a zoomed in fragment of my image.
How to maintain same dimensions ?
The ‘lv_image_set_scale’ function is changes the dimensions of the image on my screen.
EK-RA8D1
master(latest)
Zoom an image and keep same dimensions
All functions in lv_image.h
lv_obj_t * img1 = lv_image_create(lv_screen_active());
lv_image_set_src(img1, &img1);
lv_image_set_scale(img1, 256*1.4 );
lv_obj_align(img1, LV_IMAGE_ALIGN_CENTER, 0, 0);
One way to do it would be to create a base object with the desired size and then add the image object inside of it.
Here is an example:
static void zoom_evt_handler(lv_event_t * e)
    // recover image object
    lv_obj_t *img = lv_event_get_user_data(e);
    // zoom in
    lv_image_set_scale(img, 256*1.4);
void lv_example_image_1(void)
    LV_IMAGE_DECLARE(img_cogwheel_argb);
    // create frame to hold the image
    lv_obj_t *iframe = lv_obj_create(lv_screen_active());
    lv_obj_set_size(iframe, 100, 100);
    lv_obj_align(iframe, LV_ALIGN_CENTER, 0, 0);
    // optionally, remove scroll from image frame
    lv_obj_remove_flag(iframe, LV_OBJ_FLAG_SCROLLABLE);
    //add image to frame
    lv_obj_t *img1 = lv_image_create(iframe);
    lv_image_set_src(img1, &img_cogwheel_argb);
    lv_obj_align(img1, LV_ALIGN_CENTER, 0, 0);
    // zoom button
    lv_obj_t * button = lv_button_create(lv_screen_active());
    lv_obj_align(button, LV_ALIGN_CENTER, 0, 130);
    // set button callback and send image object as argument
    lv_obj_add_event_cb(button, zoom_evt_handler, LV_EVENT_CLICKED, img1);
    // button label
    lv_obj_t *label = lv_label_create(button);
    lv_label_set_text(label, "Zoom in");
    lv_obj_center(label);
Thanks. This helped a lot.
