Hello.
I found that the value set if the range exceeds 30,000 will give an incorrect value on the y axis label. Is there no way to fix it?
# Initialize
import display_driver
import lvgl as lv
# Create a button with a label
chart = lv.chart(lv.scr_act())
chart.align_to(lv.scr_act(), lv.ALIGN.TOP_MID, 100, 25)
chart.set_size(250,250)
chart.set_type(lv.chart.TYPE.LINE)
chart.set_update_mode(lv.chart.UPDATE_MODE.SHIFT)
chart.set_point_count(20)
chart.set_div_line_count(0,0)
#chart.set_range(lv.chart.AXIS.PRIMARY_Y, 10000, 20000) # Y Axis label ok
chart.set_range(lv.chart.AXIS.PRIMARY_Y, 30000, 40000) # Y Axis label error
chart.set_axis_tick(lv.chart.AXIS.PRIMARY_Y, 10, 5, 5, 5, True, 80)
series = chart.add_series(lv.color_hex(0x00eeff), lv.chart.AXIS.PRIMARY_Y)
Thank you.
