Xtaskcreatepinnedtocore doesnt run when my screen code is large
ESP32S3
lvgl v8.3.3
run lv_timer_handler() in xtaskcreatepinnedtocore function, knowing that i have one screen with more than 6718 lines (8 copied panels with different names) and it prevents the xtaskcreate function to run.
deleting the panels one by one and the code worked properly having only 3 panels.
notes to consider:
  1. flash size is 64%
  2. I have another project and its working perfectly.
  3. Arduino IDE is used.
  4. snippet code not added since I have no errors but there is a running prevention for the xtaskcreatepinnedtocore function and the same code used for different project and it works.
does the screen code size effect the performance of xtaskcreatepinnedtocore function and prevent it from entering it? any help would be appreciated
Thanks
