I developed with SquareLine Studio, TFT-eSPI and LVGL an application for tow GC9A01 displays ( 240 x240 and LV_COLOR_DEPTH 16) using Arduino (Cortex M4 - Adafruit feather CAN Express). The application works as expected in Arduino as well as in the PC simulator. When porting this application to a Cortex M4 of a Toradex / Aplais I get wrong colors.
Toradex Apalis iMX8QM - Cortex M4_1 (the second M4 of this NXP SoM).
8.3
Correct the colors
tested if White, Black Red, Green and Blue are displayed correctly (see images below)
considered if the toolchain I am using conflicts with LVGL. I used ARM GCC 13.2.rel1 and 12.2.rel.1 with newlib-nano and newlib (to see if there are some limitations in nano that impact on LVGL).
used a diferent display
checked the SPI interface and the driver for GC9A01. They work correctly as the display is initialized and the image works and the colors are displayed correctly.
N/A
- In Arduino
In Apalis LVGL
Any ideas why the colors are not correct?
Kind regards,
Florin
Hello, I think you got same issues with me, maybe wrong config init file when you config driver GC9A01. Could you take my config in this post and try again:
Hi all, because my init of the gc9a01 is wrong, that’s why it has displayed the wrong color. I have fixed it.
Now I have a good display.
[photo_2023-03-15_18-01-38]
My config init gc9a01
GC9A01A_INREGEN2, 0,
0xEB, 1, 0x14,
GC9A01A_INREGEN1, 0,
0xEB, 1, 0x14,
0x84, 1, 0x40,
0x85, 1, 0xFF,
0x86, 1, 0xFF,
0x87, 1, 0xFF,
0x88, 1, 0x0A,
0x89, 1, 0x21,
0x8A, 1, 0x00,
0x8B, 1, 0x80,
0x8C, 1, 0x01,
0x8D, 1, 0x01,
0x8E, 1, 0xFF,
0x8F, 1, 0xFF,
0xB6, 2, 0x00, 0x00,
GC9A01A_MADCTL…
Thank
Dear DucTaun,
Thanks for your suggestion. I checked your initialization file versus mine (below) and I cannot see the differences. Providing the codes you used will help spotting any differences (e.g. GC9A01A_TEON - 0x35). Please let me know if you find any.
The code below is based on the driver used by TFT_eSPI ( TFT_eSPI/TFT_Drivers at master · Bodmer/TFT_eSPI · GitHub .
Regards,
Florin
void GC9A01_Init(gc9a01_send_byte_t _writeData, gc9a01_send_byte_t _writeCommand)
//PRINTF(“In GC9A01 driver - init commands and data\r\n”);
_writeCommand(0xEF); //Inter register enable 2
_writeCommand(0xEB); // ?
_writeData(0x14);
_writeCommand(0xFE); // Inter Register Enable1
_writeCommand(0xEF); // Inter Register Enable2
_writeData(0x14);
_writeCommand(0x84);
_writeData(0x40);
_writeCommand(0x85);
_writeData(0xFF);
_writeCommand(0x86);
_writeData(0xFF);
_writeCommand(0x87);
_writeData(0xFF);
_writeCommand(0x88);
_writeData(0x0A);
_writeCommand(0x89);
_writeData(0x21);
_writeCommand(0x8A);
_writeData(0x00);
_writeCommand(0x8B);
_writeData(0x80);
_writeCommand(0x8C);
_writeData(0x01);
_writeCommand(0x8D);
_writeData(0x01);
_writeCommand(0x8E);
_writeData(0xFF);
_writeCommand(0x8F);
_writeData(0xFF);
_writeCommand(0xB6); //DISFNCTR: Display Function Control
_writeData(0x00);
_writeData(0x20); // 00??
_writeCommand(0x3A); // COLMOD: Pixel Format Set
_writeData(0x05); // 16 Bits per pixel
_writeCommand(0x90);
_writeData(0x08);
_writeData(0x08);
_writeData(0x08);
_writeData(0x08);
_writeCommand(0xBD);
_writeData(0x06);
_writeCommand(0xBC);
_writeData(0x00);
_writeCommand(0xFF);
_writeData(0x60);
_writeData(0x01);
_writeData(0x04);
_writeCommand(0xC3); // Power Control 2 - Vreg1a voltage control
_writeData(0x13);
_writeCommand(0xC4); // Power Control 3 - Vreg1b voltage control
_writeData(0x13);
_writeCommand(0xC9); // Power Control 4 - Vreg2a voltage control
_writeData(0x22);
_writeCommand(0xBE);
_writeData(0x11);
_writeCommand(0xE1); // Negative Gamma Correction
_writeData(0x10);
_writeData(0x0E);
_writeCommand(0xDF);
_writeData(0x21);
_writeData(0x0c);
_writeData(0x02);
_writeCommand(0xF0); // SET_GAMMA1
_writeData(0x45);
_writeData(0x09);
_writeData(0x08);
_writeData(0x08);
_writeData(0x26);
_writeData(0x2A);
_writeCommand(0xF1); // SET_GAMMA2
_writeData(0x43);
_writeData(0x70);
_writeData(0x72);
_writeData(0x36);
_writeData(0x37);
_writeData(0x6F);
_writeCommand(0xF2); // SET_GAMMA3
_writeData(0x45);
_writeData(0x09);
_writeData(0x08);
_writeData(0x08);
_writeData(0x26);
_writeData(0x2A);
_writeCommand(0xF3); // SET_GAMMA4
_writeData(0x43);
_writeData(0x70);
_writeData(0x72);
_writeData(0x36);
_writeData(0x37);
_writeData(0x6F);
_writeCommand(0xED);
_writeData(0x1B);
_writeData(0x0B);
_writeCommand(0xAE);
_writeData(0x77);
_writeCommand(0xCD); // ?
_writeData(0x63);
_writeCommand(0x70);
_writeData(0x07);
_writeData(0x07);
_writeData(0x04);
_writeData(0x0E);
_writeData(0x0F);
_writeData(0x09);
_writeData(0x07);
_writeData(0x08);
_writeData(0x03);
_writeCommand(0xE8); // Frame rate control
_writeData(0x34);
_writeCommand(0x62);
_writeData(0x18);
_writeData(0x0D);
_writeData(0x71);
_writeData(0xED);
_writeData(0x70);
_writeData(0x70);
_writeData(0x18);
_writeData(0x0F);
_writeData(0x71);
_writeData(0xEF);
_writeData(0x70);
_writeData(0x70);
_writeCommand(0x63);
_writeData(0x18);
_writeData(0x11);
_writeData(0x71);
_writeData(0xF1);
_writeData(0x70);
_writeData(0x70);
_writeData(0x18);
_writeData(0x13);
_writeData(0x71);
_writeData(0xF3);
_writeData(0x70);
_writeData(0x70);
_writeCommand(0x64);
_writeData(0x28);
_writeData(0x29);
_writeData(0xF1);
_writeData(0x01);
_writeData(0xF1);
_writeData(0x00);
_writeData(0x07);
_writeCommand(0x66);
_writeData(0x3C);
_writeData(0x00);
_writeData(0xCD);
_writeData(0x67);
_writeData(0x45);
_writeData(0x45);
_writeData(0x10);
_writeData(0x00);
_writeData(0x00);
_writeData(0x00);
_writeCommand(0x67);
_writeData(0x00);
_writeData(0x3C);
_writeData(0x00);
_writeData(0x00);
_writeData(0x00);
_writeData(0x01);
_writeData(0x54);
_writeData(0x10);
_writeData(0x32);
_writeData(0x98);
_writeCommand(0x74);
_writeData(0x10);
_writeData(0x85);
_writeData(0x80);
_writeData(0x00);
_writeData(0x00);
_writeData(0x4E);
_writeData(0x00);
_writeCommand(0x98);
_writeData(0x3e);
_writeData(0x07);
_writeCommand(0x35); // Tearing Effect Line ON
_writeCommand(0x21); // 0x21 - Display Inversion ON - 0x20 Display Inversion OFF
_writeCommand(0x11); // 0x11 - Sleep Out Mode - 0x10 Enter Sleep Mode
SDK_DelayAtLeastUs(120 * 1000U, SDK_DEVICE_MAXIMUM_CPU_CLOCK_FREQUENCY);
_writeCommand(0x29); // turn on the screen - Display ON
SDK_DelayAtLeastUs(20 * 1000U, SDK_DEVICE_MAXIMUM_CPU_CLOCK_FREQUENCY);
_writeCommand(0x36); // change order of RGB bits - Memory Access Control ??
_writeData(0x08); // 0x08 TFT_MAD_BGR - 0x00 - TFT_MAD_RGB - set by the Memory Acess Control - MADCRT
//_writeCommand(0xB0); // RGB Interface Signal Control
//_writeData(0x21); //
Hi Could you check with this file I saw that it have many difference
#define ILI9341_GMCTRP1 0xE0 ///< Positive Gamma Correction
#define ILI9341_GMCTRN1 0xE1 ///< Negative Gamma Correction
#define ILI9341_FRAMERATE 0xE8 ///< Frame rate control
#define GC9A01A_INREGEN2 0xEF ///< Inter register enable 2
#define GC9A01A_GAMMA1 0xF0 ///< Set gamma 1
#define GC9A01A_GAMMA2 0xF1 ///< Set gamma 2
#define GC9A01A_GAMMA3 0xF2 ///< Set gamma 3
#define GC9A01A_GAMMA4 0xF3 ///< Set gamma 4
#define GC9A01A_INREGEN1 0xFE ///< Inter register enable 1
#define MADCTL_MY 0x80 ///< Bottom to top
#define MADCTL_MX 0x40 ///< Right to left
#define MADCTL_MV 0x20 ///< Reverse Mode
#define MADCTL_ML 0x10 ///< LCD refresh Bottom to top
#define MADCTL_RGB 0x00 ///< Red-Green-Blue pixel order
#define MADCTL_BGR 0x08 ///< Blue-Green-Red pixel order
#define MADCTL_MH 0x04 ///< LCD refresh right to left
#define DISPLAY_WIDTH DT_INST_PROP(0, width)
Thanks again DucTaun! Unfortunately, I discovered only one diference between the initalization codes and that is not making a difference in terms of the colors displayed.
Kind regards,
Florin
