I am using a XMC4700 microcontroller from infineon along with LVGL to show information on a LCD screen controlled by ST7789.
I have everything working properly and there is no issue with LVGL whatsoever. But due to a errata in the XMC4700 microcontroller the system can crash in certain occasions.
In the RAM memory of the micro, if a write operation is done between the 0x1fffffff and 0x20000000 address the micro crashes if the write operation is not aligned to 4 bytes.
I have to have the VDB (Virtual display buffer) allocated between that address threshold, so, sometimes a problematic write operation can happen.
Is there any way to know where the VDB is written?
So far I found the “lv_color_fill” function in lv_color.c file. But I know there are more instances of that function.
If I find where the write operation is done, I can protect the code from performing the “forbidden” write operation.
I am using V8.2 version.
Thank you in advance,
Lander
