Hi All,
As in topic, I have a few problems with Checkbox.
First one:
I create a view with checkbox and set its state as LV_STATE_CHECKED. When I start the application, the checkbox is unchecked and its state changes after a while - about 5s (in the code we heve one sleep with 3s before for-loop and then loop from 0 to 2 with 1s sleep).
Second one:
When checkbox is unchecked and I add the state LV_STATE_CHECKED again, the checkbox appeared as white square without tick (I marked the part in the attached code).
Third one:
The properly checked checkbox lose tick when I added state LV_STATE_FOCUSED. I tried to add parent for the checkbox, and change its state to FOCUSED, but the same situation - checkbox is unchecked (only on the screen, in the code checkbox still has checked state).
Am I making something wrong or omitted something? I used the documentation and checked this code in Simulator (similar situation, but checkbox is “FOCUSED” from the beginning).
Compiler: g++ (GCC) 12.2.0, gcc (GCC) 12.2.0
LVGL 9.1 in Frame Buffer.
But the issue is also in versions 8.2, and from the master branch.
Properly working Checkbox with CHECKED status. Also, to have possibility to add FOCUSED status.
Here is small code where I reproduce problem:
#include "lvgl/lvgl.h"
#include <unistd.h>
int main(int argc, char **argv)
lv_display_t * disp = lv_linux_fbdev_create();
lv_linux_fbdev_set_file(disp, "/dev/fb0");
lv_style_t style_first;
lv_style_init(&style_first);
lv_style_set_bg_color(&style_first, lv_color_hex(0xFF00FF));
lv_style_t style_list_active;
lv_style_init(&style_list_active);
lv_style_set_bg_color(&style_list_active, lv_color_hex(0xa5a5c0));
lv_style_set_border_width(&style_list_active, 3);
lv_style_set_border_color(&style_list_active, lv_color_hex(0xFFFFFF));
lv_obj_t* first_view = lv_obj_create(NULL);
lv_obj_align(first_view, LV_ALIGN_CENTER, 0, 0);
lv_obj_set_size(first_view, lv_pct(100), lv_pct(100));
lv_obj_add_style(first_view, &style_first, 0);
lv_obj_t* checkbox = lv_checkbox_create(first_view);
lv_obj_center(checkbox);
lv_obj_add_style(checkbox, &style_list_active, LV_STATE_FOCUSED);
lv_checkbox_set_text(checkbox, "(check = true)");
lv_obj_add_state(checkbox, LV_STATE_CHECKED);
lv_scr_load(first_view);
lv_timer_handler();
sleep(3);
// **First problem is here**
for(int i = 0; i < 2; i++) {
lv_timer_handler();
sleep(1);
lv_checkbox_set_text(checkbox, "(check = false)");
lv_obj_clear_state(checkbox, LV_STATE_CHECKED);
for(int i = 0; i < 3; i++) {
lv_timer_handler();
sleep(1);
// **Second problem is here**
lv_timer_handler();
sleep(1);
lv_obj_add_state(checkbox, LV_STATE_FOCUSED);
lv_checkbox_set_text(checkbox, "(check = true) && FOCUSED");
// **Third problem is here**
lv_timer_handler();
sleep(1);
lv_checkbox_set_text(checkbox, "(check = false) && FOCUSED");
lv_timer_handler();
sleep(1);
lv_timer_handler();
sleep(1);
lv_obj_clear_state(checkbox, LV_STATE_FOCUSED);
lv_timer_handler();
sleep(1);
Screenshot just after start the app (checkbox should be checked as it is written in label):
