what are the pins that i can use without affecting the display?
I used the APSD9960.
Its has been a long time since I have worked with these WT32-SC01’s…
So not sure how I figured it out, guess checking for pin compatibility.
Anyways, it works like a charm
Hope this helps you along.
Hi, most of the PIN available on the connectors can be used, except thoses tarting by “J_”.
You can find an example of expansion board for this module here : https://github.com/bsfconception/WT32-SC01
