If I place a list as the only thing filling a page in my tabview then I can’t drag that page sideways to change tabview pages. Since I am not showing the tabs that effectively leaves the user stuck in the list page.
Teensy 4.0 - Arduino
LittleVGL for Arduino v6.0
I want the list button drag events to propagate down to the tabview page so swiping sideways works for my list
Tinkered with attributes on the list -
void createStationsWindow(lv_obj_t * page) {
//Station list
dabStationList = lv_list_create(page, NULL); //unnecessary hack?
lv_page_set_sb_mode(page, LV_SB_MODE_OFF);
lv_list_set_single_mode(dabStationList, true);
lv_page_glue_obj(dabStationList, true);
lv_obj_set_pos(dabStationList, 0, 0);
lv_obj_set_size(dabStationList, lv_page_get_scrl_width(page), LV_VER_RES - 33);
lv_list_set_sb_mode(dabStationList, LV_SB_MODE_OFF);
lv_list_set_scroll_propagation(dabStationList, true);
lv_obj_set_parent_event(dabStationList, true);
lv_obj_set_drag_parent(dabStationList, true);
lv_obj_set_drag(dabStationList, true);
with various combinations of each option.
And also the list buttons -
list_btn = lv_list_add_btn(list, LV_SYMBOL_AUDIO, name.c_str());
lv_obj_set_event_cb(list_btn, list_action);
//lv_page_glue_obj(list_btn, false);
lv_obj_set_drag(list_btn, true);
//lv_obj_set_drag_parent(list_btn, true);
lv_obj_set_parent_event(list_btn, true);
again trying various combinations, but clearly not the right one. As you can see I’m a bit in the dark as to when and where these options make sense.
void screenInit(void)
//Initialize the theme
lv_theme_t *th = lv_theme_night_init(30, NULL);
lv_theme_set_current(th);
//Create a holder page (the page become scrollable on small displays )
lv_obj_t * tabView = lv_tabview_create(lv_scr_act(), NULL);
lv_tabview_set_btns_hidden(tabView, true);
lv_tabview_set_style(tabView, LV_TABVIEW_STYLE_BG, &lv_style_transp_fit);
lv_obj_set_size(tabView, LV_HOR_RES, LV_VER_RES - 33);
lv_obj_set_pos(tabView, 0, 33);
//Create the tabs
lv_obj_t * tab1 = lv_tabview_add_tab(tabView, "Settings");
lv_obj_t * page = lv_tabview_add_tab(tabView, "Stations");
lv_obj_t * tab3 = lv_tabview_add_tab(tabView, "Main");
lv_obj_t * tab4 = lv_tabview_add_tab(tabView, "Presets");
lv_obj_t * tab5 = lv_tabview_add_tab(tabView, "Terminal");
lv_tabview_set_tab_act(tabView, 2, LV_ANIM_OFF);
lv_obj_t * label = lv_label_create(tab3, NULL);
lv_label_set_text(label, "Swipe right then try swipe left again.");
lv_obj_align(label, NULL, LV_ALIGN_CENTER, 0, 0);
//Create the contents
lv_obj_t * list1 = lv_list_create(page, NULL);
lv_list_set_single_mode(list1, true);
lv_page_glue_obj(list1, true);
lv_obj_set_pos(list1, 0, 0);
lv_obj_set_size(list1, lv_page_get_scrl_width(page), LV_VER_RES - 33);
lv_list_set_sb_mode(list1, LV_SB_MODE_OFF);
lv_list_set_scroll_propagation(list1, true);
lv_obj_set_parent_event(list1, true);
lv_obj_set_drag_parent(list1, true);
lv_obj_set_drag(list1, true);
/*Add buttons to the list*/
lv_obj_t * list_btn;
list_btn = lv_list_add_btn(list1, LV_SYMBOL_FILE, "New");
lv_obj_set_event_cb(list_btn, event_handler);
list_btn = lv_list_add_btn(list1, LV_SYMBOL_DIRECTORY, "Open");
list_btn = lv_list_add_btn(list1, LV_SYMBOL_CLOSE, "Delete");
list_btn = lv_list_add_btn(list1, LV_SYMBOL_EDIT, "Edit");
list_btn = lv_list_add_btn(list1, LV_SYMBOL_SAVE, "Save");
list_btn = lv_list_add_btn(list1, LV_SYMBOL_BELL, "Notify");
list_btn = lv_list_add_btn(list1, LV_SYMBOL_BATTERY_FULL, "Battery");
printf("Clicked: %s\n", lv_list_get_btn_text(obj));
