STM32f407
The led winking 50ms using the code:
lv_timer_t * task_1 = lv_timer_create(u_task_1, 50, ui);
void u_task_1(lv_timer_t * task_1)
lv_led_toggle(ui->screen_led_1);
It runs OK . But the screen refresh frequency will be slow if display the background img which is a bin file using fatfs load. Besides,the refresh frequency is OK if the img is C array be in MCU.
How to solve the problem? thanks a lot.
