I’m using v7.11 for my GUI and refresh my screen through LVGL Task. But I found that the task execution interval can’t meet its original setting through “lv_task_create”, e.g. the interval is 250ms, it should execute every 250ms, but now the task funciton been called 4 times every 250ms, what happened here?
I implemented more than one task, is it possible this test task been affected by others?
NXP i.MXRT1062;
IAR
v7.11
Make the task execution stable
I created a test Task which just print out the clock value (FreeRTOS clocks)
int main(void)
xTaskCreate(vGUI_Task, "littlevgl", configMINIMAL_STACK_SIZE + 6000, NULL, tskIDLE_PRIORITY + 3, &xGUI_TaskHandle);
vTaskStartScheduler();
for (;;) /* should never get here */
configASSERT(0);
void vGUI_Task(void *param)
lv_port_disp_init();
lv_port_indev_init();
/* Notify that the LVGL has ready so enable the LVGL tick */
g_lvgl_initialized = true;
SplashWinTimerCreate();
for (;;)
lv_task_handler();
vTaskDelay(5);
configASSERT(0);
vTaskDelete( NULL );
static TickType_t xLastClkTimerTest;
static TickType_t xCurrClkTimerTest;
lv_task_t* SplashWinTimerCreate(void)
lv_task_t* tsk = NULL;
static uint32_t timerTest_id = 10;
lv_task_t* tskTest = lv_task_create(testTask, 250, LV_TASK_PRIO_MID, &timerTest_id);
PRINTMSG(LOG_PRIO_INFO, "Timer created!\r\n");
xLastClkTimer = xTaskGetTickCount();
xLastClkTimerTest = xTaskGetTickCount();
return tsk;
static void testTask(lv_task_t* tsk)
xCurrClkTimerTest = xTaskGetTickCount();
char str[128];
sprintf(str, "SPLASHWIN Test Timer Interval: %d.\r\n", xCurrClkTimerTest - xLastClkTimerTest);
PRINTMSG(LOG_PRIO_INFO, str);
xLastClkTimerTest = xCurrClkTimerTest;
