I am trying to display RTL Hebrew texts according to the following LVGL’s Blog entry ‘LittlevGL speaks Hebrew’, but the base direction is always LTR. I am currently using LittlevGL 7.7.0. I have tried the following fonts:
LV_FONT_DEJAVU_16_PERSIAN_HEBREW
NotoSansHebrew-Regular.ttf (via font converter)
FrankRuehlCLM-Medium.ttf (via font converter)
Any idea of what can be happening? Thanks a lot in advance!
You are right.
What ranges do you use?
Currently Vowels and unique characters are not supported (U+059x - U+05Cx). Are you trying to use these?
Or are you using the U+FB2x - U+FB4x range?
Hi all,
Thanks @amirgon and @kisvegabor for your help! I am currently using Noto Sans Hebrew font. I am trying to represent the following characters: ﬥשׂשּטּ (0xFB38, 0xFB49, 0xFB2F, 0xFB25). These belong to the U+FB2x - U+FB4x range mentioned by @amirgon. According to Unicode standard, these characters belong to the following ranges:
No special reason, mostly because it’s unusual to use this range. I’ve never used it. I’m interested to know - what is your use case? What application needs this range?
Thanks @amirgon!
We have no clue about hebrew. I guess our application should not need this range. Anyway, as you suggest, we could eventually open a pull request if required by our application.
Have a nice weekend.
