I am having long time trouble trying to figure out how to start up LVGL v8 on my ESP32 (Platformio - Arduino framework). Down here you can see my code which I use for v8. It is exactly the same code (with some necessary changes like different buffer notation etc.).
When I am using v7 everything works just fine but with v8 at the exact moment I enter the loop task it shows this:
Board: NodeMCU ESP32S (not only one, so HW mistake is not possible)
LVGL version: v7 - working, v8 not working
Platform: PlatformIO - Arduino framework
Goal: I would like to run my code on LVGL v8 so bad…
#include <Arduino.h>
#include <lvgl.h>
#include <Ticker.h>
#include <TFT_eSPI.h>
#define LVGL_TICK_PERIOD 20
Ticker tick; /* timer for interrupt handler */
int screenWidth = 240;
int screenHeight = 320;
/* Display flushing */
uint16_t c;
tft.startWrite(); /* Start new TFT transaction */
tft.setAddrWindow(area->x1, area->y1, (area->x2 - area->x1 + 1), (area->y2 - area->y1 + 1)); /* set the working window */
for (int y = area->y1; y <= area->y2; y++) {
for (int x = area->x1; x <= area->x2; x++) {
c = color_p->full;
tft.writeColor(c, 1);
color_p++;
tft.endWrite(); /* terminate TFT transaction */
lv_disp_flush_ready(disp); /* tell lvgl that flushing is done */
/* Interrupt driven periodic handler */
static void lv_tick_handler(void)
void my_touchpad_read(lv_indev_drv_t * indev_driver, lv_indev_data_t * data)
uint16_t touchX, touchY;
bool touched = tft.getTouch(&touchX, &touchY, 600);
if(!touched)
//return false;
if(touchX > screenWidth || touchY > screenHeight)
Serial.println("x or y outside of expected parameters..");
Serial.print("y:");
Serial.print(touchX);
Serial.print(" x:");
Serial.print(touchY);
data->state = touched ? LV_INDEV_STATE_PR : LV_INDEV_STATE_REL;
/*Save the state and save the pressed coordinate*/
//if(data->state == LV_INDEV_STATE_PR) touchpad_get_xy(&last_x, &last_y);
/*Set the coordinates (if released use the last pressed coordinates)*/
data->point.x = touchX;
data->point.y = touchY;
Serial.print("Data x");
Serial.println(touchX);
Serial.print("Data y");
Serial.println(touchY);
//return false; /*Return `false` because we are not buffering and no more data to read*/
void setup()
Serial.begin(115200); /*prepare for possible serial debug*/
vTaskDelay(1000 / portTICK_PERIOD_MS);
tft.begin(); /*TFT init*/
tft.setRotation(0); /*Landscape orientation*/
uint16_t calData[5] = {261, 3548, 469, 3453, 6};
tft.setTouch(calData);
lv_disp_draw_buf_init(&disp_buf, buf, NULL, LV_HOR_RES_MAX * 10);
/*Initialize the disply*/
lv_disp_drv_t disp_drv;
lv_disp_drv_init(&disp_drv);
disp_drv.hor_res = 240;
disp_drv.ver_res = 320;
lv_disp_drv_register(&disp_drv); /*Register the driver and save the created display objects*/
/*Initialize the graphics library's tick*/
tick.attach_ms(LVGL_TICK_PERIOD, lv_tick_handler);
/*Initialize the input device driver*/
lv_indev_drv_t indev_drv;
lv_indev_drv_init(&indev_drv); /*Descriptor of a input device driver*/
indev_drv.type = LV_INDEV_TYPE_POINTER; /*Touch pad is a pointer-like device*/
indev_drv.read_cb = my_touchpad_read; /*Set your driver function*/
lv_indev_drv_register(&indev_drv); /*Finally register the driver*/
/*Create simple label*/
lv_label_set_text(label, "Hello Arduino!");
void loop()
lv_task_handler();
delay(5);
