I created a new project on cube ide for stm32f746g disco, and i included your tft and touchscreen libraries.Now tft library is working but touchscreen dont work? How can i find a solution? Help me please?
this video of;
i ’ m so sorry for my bad english
my project rar file;
Can you upload your code to GitHub (it’s easier/safer to view that way)? Did you register the touchscreen driver the same way the official project does?
Github link; https://github.com/nesetaydinn/rgbledcontrollerguiStm32f7
Yes, i got the drivers from your atollic project;
https://github.com/littlevgl/lv_port_stm32f746_disco_atollic
@embeddedt
I wait a feedback, Please give me a answer for solution.
@embeddedt
I took a look but I didn’t see anything that was done incorrectly. Try adding a debug statement to the touchpad_read function and see if it gets into there.
i added a breakpoint in touchpad_init() function. It geting into. but touchpad_read(lv_indev_drv_t *indev, lv_indev_data_t *data) not geting into. Why ? How can find a solution?
@embeddedt
Are you sure that lv_task_handler is being called after the first frame is rendered? You may want to set a breakpoint on that.
By the way, you don’t need to mention me on each post. I am notified of every post that is made on this forum.
Okey so sorry for gave mention on each post. lv_task_handler is being called.
void touchpad_init(void);
static bool touchpad_read(lv_indev_drv_t *indev, lv_indev_data_t *data);
lv_task_handler();
Strange. It must not be registering the input task, otherwise touchpad_read should get called.
I assume you are using the same lv_conf.h that our project does. Perhaps you should try stepping through lv_indev_drv_register to see if there are any errors.
