Hi @Damien_Norris ,
I am not familiar with Squareline Studio to be honest but hopefully you should be able to work with this…
Here is a function that should work for you:
void start_timer_with_count( uint32_t count) {
timer_value = count;
lv_arc_set_range(arc_1, 0, count);
lv_arc_set_value(arc_1, count);
lv_timer_reset(arc_timer);
update_knob_label( klabel );
So when you want to set the timer going for say 60 seconds just call this function as follows:
start_timer_with_count( 60 ) ;
I think this is what you are trying to achieve, if I have mis-understood, my apologies…
Here is the original example complete, but reworked with this method:
static lv_obj_t *arc_1;
static lv_obj_t *klabel;
static uint32_t timer_value = 0;
static lv_timer_t *arc_timer;
static void update_knob_label( lv_obj_t *label ) {
/*Rotate the label to the current position of the arc*/
lv_label_set_text_fmt(label, "%d", timer_value );
lv_arc_rotate_obj_to_angle(arc_1, label, 35);
static void update_arc_cb( lv_timer_t *timer ) {
if( timer_value ) lv_arc_set_value( arc_1, --timer_value );
printf( "tick:%d\r\n", lv_tick_get());
fflush(stdout);
static void btn_cb( lv_event_t *e ) {
start_timer_with_count( 60 ); // Start the timer with 60 seconds when button is pressed.
void test( lv_obj_t *parent ) {
klabel = lv_label_create( parent );
lv_obj_set_style_text_color( klabel, lv_palette_main(LV_PALETTE_BLUE), LV_PART_MAIN);
arc_1 = lv_arc_create(parent);
lv_arc_set_mode(arc_1, LV_ARC_MODE_NORMAL);
lv_arc_set_angles(arc_1, 45, 315);
lv_obj_set_style_arc_rounded(arc_1, 0, LV_PART_INDICATOR|LV_STATE_DEFAULT);
lv_obj_set_style_arc_rounded(arc_1, 0, LV_STATE_DEFAULT);
lv_obj_set_pos(arc_1, 120, 120);
lv_obj_set_size(arc_1, 100, 100);
lv_obj_t *btn = lv_btn_create( parent );
lv_obj_t *txt = lv_label_create( btn );
lv_obj_set_pos( btn, 20, 20);
lv_label_set_text( txt, "60 Secs" );
lv_obj_add_event_cb(btn, btn_cb, LV_EVENT_CLICKED, NULL);
arc_timer = lv_timer_create(update_arc_cb, 1000, arc_1);
start_timer_with_count( 10 ); // Make the timer start with 10 seconds at startup
I hope that makes sense…
If you have trouble integrating it post back with some code and I will take a look at it again a make some suggestions if necessary.
Kind Regards,
Pete
