hi,
When the size of the parent object remains unchanged, the number of child objects created and the size of child objects will be modified, and the superposition phenomenon will occur when using flex layout. This problem needs to be solved in this way.
The code is as follows
simulation result
If you reduce the number of sub objects,The code is as follows
simulation result
