I created the first lv_img’s obj that has a source from PNG file.
And I copied to the second one, but the second one can’t show anything.
File-type source of the first lv_img’s obj is copied to the second one too.
lv_obj_t *first_img;
lv_obj_t *second_img;
const char* src_file = "/sd/pictures/png_file.png";
first_img= lv_img_create(lv_scr_act(),NULL);
lv_img_set_src(first_img, src_file);
lv_obj_set_pos(first_img,0,0);
lv_obj_set_hidden(first_img, true);
second_img= lv_img_create(lv_scr_act(), first_img);
lv_obj_set_pos(second_img,180,0);
I am not a expert, but try,
const char src_file[ ] = “/sd/pictures/png_file.png”;
or
const char* src_file_pointer = &src_file;
Thank you.
The problem is not by char* variable.
The first lv_img’s obj can work well when set by
But the second lv_img’s obj that if created by copying with
second_img = lv_img_create(lv_scr_act(), first_img);
The source of the first if its type is LV_IMG_SRC_FILE
doesn’t seem copy to the second as it should to be.
can you put a screenshot?
If you debug, in lv_img_create
function, do you get to this line? :
lv_img_set_src(new_img, copy_ext->src);
CODE Test1
Test by the first lv_img’obj only, it can display well
CODE Test2
Test by copying the first obj to the second. And hidden the first.
The second can’t display anything.
(My screen’s background set to black color.)
I think the second one is hidden too. because the hidden
property is copied to the second_img from first_img.
so add this:
lv_obj_set_hidden(second_img, true);
after the creation of second_img
or hide the first one, after you create the second one.
New knowledge for me,
when create by copying, the hidden attrib is also copied.
Thank you.
