Hello for LVGL 9 I was trying to integrate a display, so for initialising the display there was an API named lv_display_set_buffers(display, buf1, buf2, buf_size_byte, render_mode), so I want to know what will be the value for buf_size_byte if I am using the 2 uint8_t buffer of size (400*200)
1 - Size of both buffers added?
2 - Size of both buffers multiplied?
3 - Size of single buffer?
I changed the buffer size as mentioned above but I think there is another issue as I have commented out the GPU-related code in lv_disp_drv_t, can anyone help with what to change for LVGL 9 if we are using the below code in lvgl 8.3, so to implement below functionality what needs to be added in LVGL
