The following boilerplate code is me attempting to draw 2d array of rectangles, for my starter project, but I’m not able to eliminate the 2 dots on every rectangle.
(The green rectangle is drawn afterwards, which is just a length 1 snake, and the green square also has weird dots, but the image is not that clear)
playground = (Playground **)malloc(sizeof(Playground *) * row_size);
for (uint8_t i = 0; i < row_size; i++)
playground[i] = (Playground *)malloc(sizeof(Playground) * col_size);
for (uint8_t j = 0; j < col_size; j++)
playground[i][j].state = EMPTY;
playground[i][j].rect = lv_obj_create(lv_scr_act());
lv_obj_set_size(playground[i][j].rect, grid_width, grid_height);
lv_obj_set_pos(playground[i][j].rect, j * grid_width, y_offset + i * grid_height);
lv_obj_set_style_border_width(playground[i][j].rect, 0, LV_PART_MAIN);
lv_obj_set_style_outline_width(playground[i][j].rect, 0, LV_PART_MAIN);
lv_obj_clear_flag(playground[i][j].rect, LV_SCROLLBAR_MODE_OFF);
lv_obj_set_style_radius(playground[i][j].rect, 0, LV_PART_MAIN);
lv_obj_set_style_bg_color(playground[i][j].rect, GROUND_COLOR, LV_PART_MAIN);
The 2 weird gray dots on every rectangle makes me think of maybe its scroll bar, but apparently I attempt to disable with lv_obj_clear_flag(playground[i][j].rect, LV_SCROLLBAR_MODE_OFF); , and no avail.
If the rectangle size is bigger, the problem does not persist, it seems to happened when the rectangle is really small.
I was thinking to remove all style, and add it back manually, I search through the whole documentation, even read the source code, but I cannot find how do I even do this.
I attempt to draw a rectangle with canvas, and the ram overflowed. it might not be a good way to do it I guess.
The whole developer experience is just so painful with not much of information, or simply I suck at programming and getting the information I need.
Any way to draw a simplest small rectangle with plain color?
