lj001
1
I upgraded the nrfConnect on VS Code toolchain from 2.5.2 to 2.6.0 and am now getting this error:
warning: attempt to assign the value '8' to the undefined symbol LV_Z_MEM_POOL_NUMBER_BLOCKS
I’m using a nRF5340 DK
I believe 8.* but I’m not sure how I check from VS Code
When I switch toolchains back to 2.5.2 it compiles and runs fine.
lj001
2
I got a reply from Nordic Dev Zone:
It seems the way the LVGL heap is configured is handled a bit differently in the latest version.
In v2.5.2 the heap was scaled based on the LV_Z_MEM_POOL_MAX_SIZE and LV_Z_MEM_POOL_NUMBER_BLOCKS parameters as seen here.
In the later version this was simplified to use just a single parameter, LV_Z_MEM_POOL_SIZE, as seen here.
In other words you should change your project configuration to use this new parameter.
The commit log provides a bit more context:
Best regards
Torbjørn
