Virtual Keyboard
I’m implementing the virtual keyboard widget on my application, I took the basic example https://docs.lvgl.io/master/details/widgets/keyboard.html.
If I define the keyboard and the text area as children of “parent” after the first digit it freezes and does not let me proceed, while if they are children of the active screen it works correctly.
How can i solve it?
static void ta_event_cb(lv_event_t * e)
	lv_obj_t * ta = lv_event_get_target_obj(e);
	lv_obj_t * kb = (lv_obj_t *)lv_event_get_user_data(e);
	if(code == LV_EVENT_FOCUSED)
			lv_keyboard_set_textarea(kb, ta);
			lv_obj_remove_flag(kb, LV_OBJ_FLAG_HIDDEN);
	if(code == LV_EVENT_DEFOCUSED)
			lv_keyboard_set_textarea(kb, NULL);
			lv_obj_add_flag(kb, LV_OBJ_FLAG_HIDDEN);
void SettingPage(lv_obj_t * parent)
	/*Create a keyboard to use it with an of the text areas*/
    lv_obj_t * kb = lv_keyboard_create(parent);
    /*Create a text area. The keyboard will write here*/
    lv_obj_t * ta1;
    ta1 = lv_textarea_create(parent);
    lv_obj_align(ta1, LV_ALIGN_TOP_LEFT, 10, 10);
    lv_obj_add_event_cb(ta1, ta_event_cb, LV_EVENT_ALL, kb);
    lv_textarea_set_placeholder_text(ta1, "Hello");
    lv_obj_set_size(ta1, 140, 80);
    lv_keyboard_set_textarea(kb, ta1);
  • MCU/MPU/Board: STM32F746BGT
  • LVGL version: 9.3.0
I encountered the same problem using sliders and dropdowns, if I create sub-panels and these objects are children of these sub-panels the touch does not work, while if they are direct children of the main panel of the current tab I have no problems
Does anyone know how to fix this?
I tested the code you shared above, and it works fine.
Could you share more code about the ‘parent’ item?
