Versions compatible with ESP-IDF
does anyone know what versions are compatible with ESP-IDF. Currently i have ESPv5.3.1 with lvgl 9.2.2. I keep getting errors in my code.
#include "esp_lcd_panel_io.h"
#include "esp_lcd_panel_vendor.h"
#include "esp_lcd_panel_ops.h"
#include "driver/spi_master.h"
#include "driver/gpio.h"
#include "lvgl.h"
#include "esp_log.h"
#include "freertos/task.h"
#define TAG "ST7789"
// Define SPI pins
#define PIN_NUM_MOSI  13
#define PIN_NUM_CLK   14
#define PIN_NUM_CS    15
#define PIN_NUM_DC     2
#define PIN_NUM_RST   -1
#define PIN_NUM_BL    21
// LVGL buffer size
#define DISP_BUF_SIZE (240 * 20)
static const spi_host_device_t HOST_ID = SPI2_HOST;
// LVGL flush callback
void disp_driver_flush(lv_disp_drv_t *drv, const lv_area_t *area, lv_color_t *color_map) {
    esp_lcd_panel_handle_t panel_handle = (esp_lcd_panel_handle_t)drv->user_data;
    esp_lcd_panel_draw_bitmap(panel_handle, area->x1, area->y1, area->x2 + 1, area->y2 + 1, color_map);
    lv_disp_flush_ready(drv);
void app_main() {
    // Initialize SPI bus
    spi_bus_config_t buscfg = {
        .sclk_io_num = PIN_NUM_CLK,
        .mosi_io_num = PIN_NUM_MOSI,
        .miso_io_num = -1,
        .quadwp_io_num = -1,
        .quadhd_io_num = -1,
        .max_transfer_sz = 320 * 240 * 2 + 10,
    ESP_ERROR_CHECK(spi_bus_initialize(HOST_ID, &buscfg, SPI_DMA_CH_AUTO));
    // Configure panel IO
    esp_lcd_panel_io_spi_config_t io_config = {
        .dc_gpio_num = PIN_NUM_DC,
        .cs_gpio_num = PIN_NUM_CS,
        .pclk_hz = 40 * 1000 * 1000,
        .spi_mode = 0,
        .trans_queue_depth = 10,
    esp_lcd_panel_io_handle_t io_handle;
    ESP_ERROR_CHECK(esp_lcd_new_panel_io_spi(HOST_ID, &io_config, &io_handle));
    // Configure panel
    esp_lcd_panel_dev_config_t panel_config = {
        .reset_gpio_num = PIN_NUM_RST,
        .rgb_endian = ESP_LCD_COLOR_SPACE_BGR,
        .bits_per_pixel = 16,
    esp_lcd_panel_handle_t panel_handle;
    ESP_ERROR_CHECK(esp_lcd_new_panel_st7789(io_handle, &panel_config, &panel_handle));
    ESP_ERROR_CHECK(esp_lcd_panel_reset(panel_handle));
    ESP_ERROR_CHECK(esp_lcd_panel_init(panel_handle));
    ESP_ERROR_CHECK(esp_lcd_panel_disp_on_off(panel_handle, true));
    if (PIN_NUM_BL != -1) {
        gpio_config_t bk_gpio_config = {
            .pin_bit_mask = 1ULL << PIN_NUM_BL,
            .mode = GPIO_MODE_OUTPUT,
        gpio_config(&bk_gpio_config);
        gpio_set_level(PIN_NUM_BL, 1);
    // Initialize LVGL
    // Configure LVGL buffer
    static lv_color_t buf1[DISP_BUF_SIZE];
    static lv_color_t buf2[DISP_BUF_SIZE];
    lv_disp_draw_buf_init(&disp_buf, buf1, buf2, DISP_BUF_SIZE);
    // Register the display driver in LVGL
    lv_disp_drv_t disp_drv;
    lv_disp_drv_init(&disp_drv);
    disp_drv.flush_cb = disp_driver_flush;
    disp_drv.hor_res = 240;
    disp_drv.ver_res = 320;
    disp_drv.user_data = panel_handle;
    // Create a simple label
    lv_label_set_text(label, "Hello, ST7789 with LVGL!");
    ESP_LOGI(TAG, "Initialization complete, entering LVGL task loop");
    while (1) {
        lv_task_handler();
	"resource": "/c:/Workspace/ESP-IDF/test/main/hello_world_main.c",
	"owner": "cpp",
	"severity": 8,
	"message": "unknown type name 'lv_disp_drv_t'; did you mean 'lv_fs_drv_t'?",
	"startLineNumber": 27,
	"startColumn": 24,
	"endLineNumber": 27,
	"endColumn": 24
	"owner": "C/C++: IntelliSense",
	"code": "20",
	"severity": 8,
	"message": "identifier \"lv_disp_drv_t\" is undefined",
	"source": "C/C++",
	"startColumn": 24,
	"endColumn": 37
	"owner": "cpp",
	"severity": 8,
	"message": "unknown type name 'lv_disp_draw_buf_t'",
	"startLineNumber": 84,
	"startColumn": 12,
	"endLineNumber": 84,
	"endColumn": 12
	"code": "20",
	"severity": 8,
	"message": "identifier \"lv_disp_draw_buf_t\" is undefined",
	"source": "C/C++",
	"startColumn": 12,
	"endColumn": 30
	"owner": "cpp",
	"severity": 8,
	"message": "implicit declaration of function 'lv_disp_draw_buf_init'; did you mean 'lv_draw_buf_init'? [-Werror=implicit-function-declaration]",
	"startLineNumber": 85,
	"startColumn": 5,
	"endLineNumber": 85,
	"endColumn": 5
	"owner": "cpp",
	"severity": 8,
	"startLineNumber": 88,
	"startColumn": 5,
	"endLineNumber": 88,
	"endColumn": 5
	"code": "20",
	"severity": 8,
	"source": "C/C++",
	"startColumn": 5,
	"endColumn": 18
	"owner": "cpp",
	"severity": 8,
	"message": "implicit declaration of function 'lv_disp_drv_init'; did you mean 'lv_fs_drv_init'? [-Werror=implicit-function-declaration]",
	"startLineNumber": 89,
	"startColumn": 5,
	"endLineNumber": 89,
	"endColumn": 5
	"owner": "cpp",
	"severity": 8,
	"message": "request for member 'flush_cb' in something not a structure or union",
	"startLineNumber": 90,
	"startColumn": 13,
	"endLineNumber": 90,
	"endColumn": 13
	"owner": "cpp",
	"severity": 8,
	"message": "'disp_driver_flush' undeclared (first use in this function)",
	"startColumn": 25,
	"endColumn": 25
	"owner": "cpp",
	"severity": 8,
	"message": "request for member 'draw_buf' in something not a structure or union",
	"startLineNumber": 91,
	"startColumn": 13,
	"endLineNumber": 91,
	"endColumn": 13
	"owner": "cpp",
	"severity": 8,
	"message": "request for member 'hor_res' in something not a structure or union",
	"startLineNumber": 92,
	"startColumn": 13,
	"endLineNumber": 92,
	"endColumn": 13
	"owner": "cpp",
	"severity": 8,
	"message": "request for member 'ver_res' in something not a structure or union",
	"startLineNumber": 93,
	"startColumn": 13,
	"endLineNumber": 93,
	"endColumn": 13
	"owner": "cpp",
	"severity": 8,
	"message": "request for member 'user_data' in something not a structure or union",
	"startLineNumber": 94,
	"startColumn": 13,
	"endLineNumber": 94,
	"endColumn": 13
	"owner": "cpp",
	"severity": 8,
	"message": "implicit declaration of function 'lv_disp_drv_register'; did you mean 'lv_fs_drv_register'? [-Werror=implicit-function-declaration]",
	"startLineNumber": 95,
	"startColumn": 5,
	"endLineNumber": 95,
	"endColumn": 5
It’s always a good idea to check the latest port and LVGL library versions in the Espressif Components Library:
https://components.espressif.com/components/espressif/esp_lvgl_port/versions/2.9.0/readme
https://components.espressif.com/components/lvgl/lvgl/versions/9.5.0/readme
It will show you the latest compatible versions.
