Using this code…
import lvgl as lv
from ili9XXX import ili9341
from xpt2046 import xpt2046
disp = ili9341(spihost=2, miso=19, mosi=23, clk=18, cs=15, dc=13, rst=0, backlight=27, mhz=10, factor=4, half_duplex=False, double_buffer=True, power_on=1, backlight_on=1) # half_duplex do not work with SDCard
touch = xpt2046(spihost=2, cs=5)
def button_cb(e):
print("Clicked")
# Screen Objects
scr = lv.scr_act()
btn = lv.btn(scr)
btn.center()
btn.add_event(button_cb, lv.EVENT.CLICKED, None)
label = lv.label(btn)
label.set_text("CLICK Me")
lv.scr_load(scr)
After a ~ 2 minutes or a couple of touches, getting
Double buffer
ILI9341 initialization completed
Enable backlight
MicroPython v1.20.0-700-g841ece132-dirty on 2023-07-28; ESP32 module (spiram) with ESP32
Type "help()" for more information.
>>> Guru Meditation Error: Core 1 panic'ed (LoadProhibited). Exception was unhandled.
Core 1 register dump:
PC : 0x40084b99 PS : 0x00060630 A0 : 0x800de23b A1 : 0x3ffdebe0
A2 : 0x00000006 A3 : 0x00000ed2 A4 : 0x00000000 A5 : 0x00000006
A6 : 0x003fffff A7 : 0x00060823 A8 : 0x00000000 A9 : 0x3ffdebd0
A10 : 0x3f81b400 A11 : 0x3f403c74 A12 : 0x3ffd2028 A13 : 0x0000026e
A14 : 0x000003d6 A15 : 0x0000000c SAR : 0x0000001c EXCCAUSE: 0x0000001c
EXCVADDR: 0x00000006 LBEG : 0x4009620e LEND : 0x40096219 LCOUNT : 0x00000000
Backtrace: 0x40084b96:0x3ffdebe0 0x400de238:0x3ffdec10 0x400ff90c:0x3ffdec30 0x40127f93:0x3ffdec60 0x401285d8:0x3ffdec80 0x4014076c:0x3ffdecd0 0x400fd7df:0x3ffded00 0x400fc233:0x3ffded20 0x40107895:0x3ffded40 0x400e55b6:0x3ffded60 0x400e5706:0x3ffded80 0x40086515:0x3ffdeda0 0x400df050:0x3ffdee40 0x400e55b6:0x3ffdee70 0x40121c52:0x3ffdee90 0x40121c85:0x3ffdeed0 0x400e55b6:0x3ffdeef0 0x400e56bf:0x3ffdef10 0x400e60ea:0x3ffdef40 0x400e6274:0x3ffdefc0 0x400d87be:0x3ffdefe0 0x400f1f9d:0x3ffdf000 0x400f280e:0x3ffdf020 0x400d855c:0x3ffdf060
xtensa-esp32-elf-addr2line...
0x40084b96: mp_map_lookup at /mnt/d/SmartLOG_V2/lv_micropython/py/map.c:156
0x400de238: mp_obj_dict_get at /mnt/d/SmartLOG_V2/lv_micropython/py/objdict.c:213
0x400ff90c: lv_indev_t_read_cb_callback at /mnt/d/SmartLOG_V2/lv_micropython/ports/esp32/build-GENERIC_SPIRAM/lv_mp.c:23211
0x40127f93: _lv_indev_read at /mnt/d/SmartLOG_V2/lv_micropython/lib/lv_bindings/lvgl/src/core/lv_indev.c:158
0x401285d8: lv_indev_read_timer_cb at /mnt/d/SmartLOG_V2/lv_micropython/lib/lv_bindings/lvgl/src/core/lv_indev.c:188
(inlined by) lv_indev_read_timer_cb at /mnt/d/SmartLOG_V2/lv_micropython/lib/lv_bindings/lvgl/src/core/lv_indev.c:166
0x4014076c: lv_timer_exec at /mnt/d/SmartLOG_V2/lv_micropython/lib/lv_bindings/lvgl/src/misc/lv_timer.c:346
(inlined by) lv_timer_handler at /mnt/d/SmartLOG_V2/lv_micropython/lib/lv_bindings/lvgl/src/misc/lv_timer.c:114
(inlined by) lv_timer_handler at /mnt/d/SmartLOG_V2/lv_micropython/lib/lv_bindings/lvgl/src/misc/lv_timer.c:71
0x400fd7df: lv_task_handler at /mnt/d/SmartLOG_V2/lv_micropython/lib/lv_bindings/lvgl/src/lv_api_map.h:42
0x400fc233: mp_lv_task_handler at /mnt/d/SmartLOG_V2/lv_micropython/ports/esp32/build-GENERIC_SPIRAM/lv_mp.c:24037
0x40107895: lv_fun_builtin_var_call at /mnt/d/SmartLOG_V2/lv_micropython/ports/esp32/build-GENERIC_SPIRAM/lv_mp.c:103
0x400e55b6: mp_call_function_n_kw at /mnt/d/SmartLOG_V2/lv_micropython/py/runtime.c:695
0x400e5706: mp_call_method_n_kw at /mnt/d/SmartLOG_V2/lv_micropython/py/runtime.c:711
0x40086515: mp_execute_bytecode at /mnt/d/SmartLOG_V2/lv_micropython/py/vm.c:1042
0x400df050: fun_bc_call at /mnt/d/SmartLOG_V2/lv_micropython/py/objfun.c:278
0x40121c52: mp_call_method_self_n_kw at /mnt/d/SmartLOG_V2/lv_micropython/py/objboundmeth.c:70
0x40121c85: bound_meth_call at /mnt/d/SmartLOG_V2/lv_micropython/py/objboundmeth.c:83
0x400e56bf: mp_call_function_1 at /mnt/d/SmartLOG_V2/lv_micropython/py/runtime.c:673
0x400e60ea: mp_call_function_1_protected at /mnt/d/SmartLOG_V2/lv_micropython/py/runtime_utils.c:33
0x400e6274: mp_sched_run_pending at /mnt/d/SmartLOG_V2/lv_micropython/py/scheduler.c:110
(inlined by) mp_handle_pending at /mnt/d/SmartLOG_V2/lv_micropython/py/scheduler.c:239
0x400d87be: mp_hal_stdin_rx_chr at /mnt/d/SmartLOG_V2/lv_micropython/ports/esp32/mphalport.c:103
0x400f1f9d: readline at /mnt/d/SmartLOG_V2/lv_micropython/shared/readline/readline.c:560
0x400f280e: pyexec_friendly_repl at /mnt/d/SmartLOG_V2/lv_micropython/shared/runtime/pyexec.c:610
0x400d855c: mp_task at /mnt/d/SmartLOG_V2/lv_micropython/ports/esp32/main.c:181
PS D:\SmartLOG_V2>
Does anything stand out ???
