V9.2.0 lv_menu Questions
Is it possible to apply a style to a lv_menu?
I wish to align the Menu Heading to the center of the screen, I have searched but I am unable to find a solution that is V9.2.0.compliant or even an example snippet of code I can experiment with.
I wish to also reduce the vertical spacing between lv_menu labels, I have experimented with changing the default font to a small one in lv_conf.h and the vertical spacing appear to be constant, is it possible to adjust this spacing to make it smaller than what it currently is?
Kind Regards
Paul
I have created 2 panels, one for the menu title, So I can now align the label to the center of the small panel.
I am still unable to align the menu items in my menu list to the center of the panel I have forced the menu to be created in. I have tried applying a style to the menu widget with no success.
Any ideas that I can try?
Hi All,
I am still trying every possible setting option, I can find in the documentation, that the menu widget has with no success, I cannot see in the documentation if styling a menu widget is possible.
At present I am only able to alter Font and Font color of the Menu items, I still wish to adjust the following:
a) Vertical spacing between menu items - I feel the listed items are to far apart
b) Have the ability to ALIGN the menu items to the vertical center of the display
c) force the alignment of an object displayed in a container (child menu page) to be moved to the extreme left as presently the container is padded by approx. 10 or so pixels
Any help with be greatly appreciated.
Regards
Paul
