I’m trying to hide the back button when using the lv_menu on subpages.
LVGL Simulator with Linux and Micropython Online Simulator
8.3
I want to achieve a menu that does not force subpages to use the current back button. Is this possible currently with the lv_menu widget and if not is there a better way to go about styling the back button for a subpage.
I have tried using the root back button styling lv_menu_set_mode_root_back_btn(menu, LV_MENU_ROOT_BACK_BTN...) on subpages but it gives a runtime error because it isn’t the correct object type.
The following code runs in the online micropython simulator for convenience.
##### startup script #####
#!/opt/bin/lv_micropython -i
import lvgl as lv
import display_driver
##### main script #####
# Create a menu object
menu = lv.menu(lv.scr_act())
menu.set_mode_root_back_btn(lv.menu.ROOT_BACK_BTN.DISABLED)
menu.set_size(320, 240)
menu.center()
# Create a sub page
sub_page = lv.menu_page(menu, None)
cont = lv.menu_cont(sub_page)
label = lv.label(cont)
label.set_text("^ How do I get rid of this")
# Create a main page
main_page = lv.menu_page(menu, None)
cont = lv.menu_cont(main_page)
label.set_text("Next (click me)")
menu.set_load_page_event(cont, sub_page)
menu.set_page(main_page)
