I have a button matrix to input a PIN.
The buttons will register if the touch is dragged. I want to avoid this behavior, as it causes unwanted inputs (watch gif - first input of pin is the expected behavior, second input is the unwanted behavior).
Simulator (Eclipse)
ESP32 (IDF)
7.3.1
Registering button input in a button matrix only if the touch was released.
Tried to register input on release instead of press, but the result is the same.
Default button matrix on a 3x4 grid.
EDIT
Is there anyway to know the touch status (pressed/not pressed)? Could create a registry to know if when a button is pressed there were any touch inputs in the previous (mili-)seconds.
EDIT 2
Reading on the Porting section on the docs right now.
EDIT 3
For clarification, here’s the physical version of the issue, might be easier to understand:
It registers button click even if I don’t lift the pen from the screen and drag it around the keyboard.
