MIMXRT1040 EVK and Zephyr, LVGL v8.3.7
Use PXP
I have modified files lv_gpu_nxp_pxp_osa.c/h for usage with the Zephyr platform. The PXP IRQ gets called, however there’s a lot of artifacts on the screen
lv_gpu_nxp_pxp_osa.c (4.1 KB)
* Copyright (c) 2018 Jan Van Winkel <jan.van_winkel@dxplore.eu>
* SPDX-License-Identifier: Apache-2.0
#include <zephyr/device.h>
#include <zephyr/devicetree.h>
#include <zephyr/drivers/display.h>
#include <zephyr/drivers/gpio.h>
#include <lvgl.h>
#include <stdio.h>
#include <string.h>
#include <zephyr/kernel.h>
#include <lvgl_input_device.h>
#include <zephyr/drivers/kscan.h>
#define LOG_LEVEL CONFIG_LOG_DEFAULT_LEVEL
#include <zephyr/logging/log.h>
LOG_MODULE_REGISTER(app);
static lv_obj_t * meter;
static void set_value(void * indic, int32_t v)
lv_meter_set_indicator_end_value(meter, indic, v);
* A meter with multiple arcs
void lv_example_meter_2(void)
meter = lv_meter_create(lv_scr_act());
lv_obj_center(meter);
lv_obj_set_size(meter, 200, 200);
/*Remove the circle from the middle*/
lv_obj_remove_style(meter, NULL, LV_PART_INDICATOR);
/*Add a scale first*/
lv_meter_scale_t * scale = lv_meter_add_scale(meter);
lv_meter_set_scale_ticks(meter, scale, 11, 2, 10, lv_palette_main(LV_PALETTE_GREY));
lv_meter_set_scale_major_ticks(meter, scale, 1, 2, 30, lv_color_hex3(0xeee), 15);
lv_meter_set_scale_range(meter, scale, 0, 100, 270, 90);
/*Add a three arc indicator*/
lv_meter_indicator_t * indic1 = lv_meter_add_arc(meter, scale, 10, lv_palette_main(LV_PALETTE_RED), 0);
lv_meter_indicator_t * indic2 = lv_meter_add_arc(meter, scale, 10, lv_palette_main(LV_PALETTE_GREEN), -10);
lv_meter_indicator_t * indic3 = lv_meter_add_arc(meter, scale, 10, lv_palette_main(LV_PALETTE_BLUE), -20);
/*Create an animation to set the value*/
lv_anim_t a;
lv_anim_init(&a);
lv_anim_set_exec_cb(&a, set_value);
lv_anim_set_values(&a, 0, 100);
lv_anim_set_repeat_delay(&a, 100);
lv_anim_set_playback_delay(&a, 100);
lv_anim_set_repeat_count(&a, LV_ANIM_REPEAT_INFINITE);
lv_anim_set_time(&a, 2000);
lv_anim_set_playback_time(&a, 500);
lv_anim_set_var(&a, indic1);
lv_anim_start(&a);
lv_anim_set_time(&a, 1000);
lv_anim_set_playback_time(&a, 1000);
lv_anim_set_var(&a, indic2);
lv_anim_start(&a);
lv_anim_set_playback_time(&a, 2000);
lv_anim_set_var(&a, indic3);
lv_anim_start(&a);
int main(void)
const struct device *display_dev;
display_dev = DEVICE_DT_GET(DT_CHOSEN(zephyr_display));
if (!device_is_ready(display_dev))
LOG_ERR("Device not ready, aborting test");
return 0;
lv_example_meter_2();
lv_task_handler();
display_blanking_off(display_dev);
while (1)
lv_task_handler();
k_sleep(K_MSEC(5));
