Trying to use a PMOLED in monochrome.
STM32F4
7.0.1
Want to initialize LVGL with PMOLED background BLACK, text, symbols, and lines, etc in WHITE.
In lv_conf.h, I have set the followings:
#define LV_USE_THEME_EMPTY 1
#define LV_USE_THEME_TEMPLATE 1
#define LV_USE_THEME_MATERIAL 1
#define LV_USE_THEME_MONO 1
#define LV_THEME_DEFAULT_COLOR_PRIMARY LV_COLOR_WHITE
#define LV_THEME_DEFAULT_FLAG LV_THEME_MATERIAL_FLAG_LIGHT
The OLED displays a picture and static text properly, but the whole screen changed to a white background somehow. I am using a bitwise frame-buffer similar to that of Sharp MIP:
#define DEV_BUFIDX(x, y) ((x >> 3) + (y*(LV_HOR_RES_MAX >> 3)))
#define PIXIDX(x) (1 << ((x) & 7))
In the callback function to set pixel, I use:
void mydisp_set_px_cb(lv_disp_drv_t * disp_drv, uint8_t * buf, lv_coord_t buf_w, lv_coord_t x, lv_coord_t y, lv_color_t color, lv_opa_t opa) {
(void) disp_drv;
(void) buf_w;
(void) opa;
lv_coord_t _x,_y;
//also working on a runtime screen orientation change.
#if defined (LV_SCREEN_ROTATE_270)
_x = y;
_y = (LV_HOR_RES_MAX-1)-x;
#elif defined (LV_SCREEN_ROTATE_180)
_x = (LV_HOR_RES_MAX-1)-x;
_y = (LV_VER_RES_MAX-1)-y;
#elif defined (LV_SCREEN_ROTATE_90)
_x = (LV_VER_RES_MAX-1)-y;
_y = x;
#else
_x = x;
_y = y;
if (lv_color_to1(color) == 1) {
buf[DEV_BUFIDX(_x, _y)] |= PIXIDX(_x); //Set VDB pixel bit to 1 for other colors than BLACK
} else {
buf[DEV_BUFIDX(_x, _y)] &= ~PIXIDX(_x); //Set VDB pixel bit to 0 for BLACK color
I did an online debug and I was able to trace the actual function that sets the background white. It is located in lv_draw_rect.c::draw_bg(coords, clip, dsc) at line 97. After stepping through this function, the screen turns white, setting the whole frame buffer 0xff.
I am wondering if a style is required for MONOCHROME? I have not applied any style yet. The lv_hal_init() is short with snippet below:
void lv_hal_init(void)
mydisp_init(); //a proven function to initialize the display will bg=BLACK, fg=WHITE, writing a bit 0=BLACK, 1=WHITE
static lv_disp_buf_t lv_disp_buf;
static lv_color_t lv_buf_array[LV_HOR_RES_MAX*LV_VER_RES_MAX];
lv_disp_buf_init(&lv_disp_buf, lv_buf_array, NULL, LV_HOR_RES_MAX*LV_VER_RES_MAX);
lv_disp_drv_t disp_drv;
//disp_drv.rotated = 1;
lv_disp_drv_init(&disp_drv);
disp_drv.buffer = &lv_disp_buf;
disp_drv.flush_cb = mydisp_flush_cb;
disp_drv.set_px_cb = mydisp_set_px_cb;
The expected result is a black background with white text. But it is now inverted.
